Thread: 150 ecu on a 130?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. 150 ecu on a 130?
    Feb 2010
    Chepstow
    Are teh 1.9 tdi bora engines (130 150 ) both the same??
    Thinking of putting a 150 ecu on my 130.. far cheaper option
  2. Re: 150 ecu on a 130?
    Chester-le-Street, United Kingdom
    Quote Originally Posted by thejean1 View Post
    cheaper option than what exactly ?
    as far i'm i'm aware, the 150 has a larger turbo,and different injectors,but don't quote me,i'm not 100% about the injectors, otherwise the same block and head i believe,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: 150 ecu on a 130?
    the units have different part numbers,which basically means they are not the same
  4. Re: 150 ecu on a 130?
    Feb 2010
    Chepstow
    so how come you can map a 130 to 165 without changing anything mechanically?
  5. Re: 150 ecu on a 130?
    Feb 2010
    Chepstow
    Quote Originally Posted by STEWY L View Post
    regards,
    stewy.
    than a remap.. i need to be 100% sure or else i will blow my engine up :/
  6. Re: 150 ecu on a 130?
    in the same way that you can map a 150 to a whole lot more!
    changing fuel input and timing thus spooling turbo up earlier,it's more complicated than that no doubt,but that's the basics,remember though, it's the torque that gets developed, rather than the horsepower that makes the drive better,
    regards,
    stewy.
    4th cog,--two to go
  7. Re: 150 ecu on a 130?
    Feb 2010
    Chepstow
    regards,
    stewy.
    yea i understand that im not trying to get huge results here.. otherwise id buy something faster to begin with. Im just asking wether the engines are the same or not and if it is possible to fit a 150 ecu on a 130 engine... Theoretically i see no problem in doing so i just want to make sure
  8. Re: 150 ecu on a 130?
    Norfolk
    It is fairly easy to remap a 130 to 150 using cheap chinese hardware and a bit of knowledge from a chip tuning website. If you just stick a 150 ecu on a130 the car won't start, so you will need to work out how to code in the different ecu.
  9. Re: 150 ecu on a 130?
    Feb 2010
    Chepstow
    Quote Originally Posted by martin1810 View Post
    i need the ecu because mine is faulty.. so thought i might as well get a 150.. are you sure? im pretty sure someone i know has done it a vauxhall (but the same ecu not a more powerfuly mapped one..)
  10. Re: 150 ecu on a 130?
    Norfolk
    I have not tried swapping a 130 ecu for a 150 ecu for the simple reason that I know the map contents are not the same. You can't take a 130 ecu off and swap it with another 130 ecu and be sure the car will start. You have to have the exact hardware and software match. Even then you have to code the ecu to the car. Try and see what happens. My guess is the car won't start. The ecu contains a huge amount of data.
  1. Remapped 130 or remapped 150? Opinions!
    By The Bishmeister in forum Golf MK4 - 1999 - 2004
    Last Post: 26-09-2008, 05:20 PM
  2. Ecu Remap 1.9 tdi 130
    By Slinetugga in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2008, 07:12 PM
  3. a3 tdi 130
    By u5man in forum Audi A3 - Archive Topics
    Last Post: 13-03-2008, 06:55 PM
  4. GTI to GT TDI
    By gwyn in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-05-2007, 02:10 PM
  5. Updated ECU Golf 130 GT TDI (2002) /ASZ
    By arena432 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-03-2005, 07:23 PM
