Thread: cruise control retrofit
Results 1 to 10 of 11
  1. cruise control retrofit
    Ireland
    Hi all,
    Looking at purchasing this cruise control unit for a 02 B6 A4 AVJ 1.8T.
    http://cgi.ebay.co.uk/Audi-A4-8E-A6-...item53e1f37654
    Question I have is how do I know if I need to purchase the extra controller for 165 pounds as stated in note below. Is there an easy way to check this?
    Thanks..
    Please note: On some model's with a Lowline 'On Board Computer' the Steering controller modules (Part Numbers: 8E0953549F, 8E0953549S) cannot accept the Cruise Control coding, if this is the case a new controller will be required which we can supply at an extra £165.
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  2. Re: cruise control retrofit
    Southern County Softy
    20 Post(s)
    there is a DIS and cruise retrofit thread that has all the info.
    A scan with VCDS will give you your SCCM part No. or remove the steering wheel
    and look at the No. on the SCCM
    A4 2.5 tdi QS (mapped)
  3. Re: cruise control retrofit
    Ireland
    Quote Originally Posted by kite View Post
    Thanks for that, just checked and not good news.
    See attached.
    Might give it a miss now as thats a bit more then i wanted to pay for it... pity..
    Do you know if there is any other advantage to paying for the extra controller.
    15 535d 313bhp
    VCDS HEX V2
  4. Re: cruise control retrofit
    20 Post(s)
    you might find 1 on the bay....
  5. Re: cruise control retrofit
    Nov 2008
    N/A
    I believe the extra controller also supports the multi-function steering wheel. Which is ugly. But I wouldn't give it up because it's brilliant. But ugly.
  6. Re: cruise control retrofit
    Jul 2009
    liskeard cornwall
    doing the research myself to fit cruise control to my a4 i found audi to be the best and cheapest option and they tell you all the info you need too know-ie part no and cost, fantastic. use audi and not ebay
  7. Re: cruise control retrofit
    Sep 2008
    Saltburn, England
    The OP still needs a new SCCM to have cruise regardless if its purchased via a dealer on eBay or by visiting your local Audi Dealer
    A bit more info on controllers required; http://wiki.ross-tech.com/wiki/index...Control_Module
    Luckily my 2006 S4 has a 'Q' Highline version
  8. Re: cruise control retrofit
    May 2007
    knee deep in clunge
    14 Post(s)
    cruise switch £30 from dealer or http://www.ebay.co.uk/itm/Cruise-Con...#ht_900wt_1187
    steering control unit http://www.ebay.co.uk/sch/i.html?_fr...nkw=8E0953549q
    lower cowling from dealer £25
    also replace the clutch switch as a precaution £12 from dealer (they tend to fail without fault code or any running problems so fit a new one)
  9. Re: cruise control retrofit
    Aug 2010
    Matlock UK
    Thanks to all for contributions to an interesting thread. Is this modification to add cruise control also possible on A4 B8 (2009) vehicles? The switch looks identical but does the vehicle allow this change to be made?
  10. Re: cruise control retrofit
    Sep 2008
    Saltburn, England
    Those prices are a little out of date or you've not included VAT
    The 2009 A4 B8 uses a combined indicator & wiper stalk, so the B7 kit will not fit.
    VW Teesside in Saltburn supply new A4 B8 cruise kits for around £200 in parts & £60 fitting.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Retrofit Cruise Control
    By Desmo in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-11-2012, 10:05 PM
  4. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  5. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
