Thread: Help - Need adapter 7 pin to VW tow bar skt
  1. Help - Need adapter 7 pin to VW tow bar skt
    Jul 2009
    bath, england
    I just bought a small Trailer (Erde 102). It apparently has a 7 pin plug to connect the electrics.
    I have a factory fit towbar (detachable) on my MK6 Golf. What exactly do I need to connect the two?
    I am confused by 12, 13 pin and 7 pin adapters
    Any help appreciated. I expect as I am in a hurry I will have to got to one of the local suppliers (Halfords etc) tomorrow to pick one up.
    Also need to source a number plate on a Sunday! - Kwik Fit are supposed to do them, but grateful if anyone can suggest another chain that might do them.
  2. Re: Help - Need adapter 7 pin to VW tow bar skt
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Well the standard 7 pin socket and plug should be wired in the correct sequence. If you have the factory towbar fitted then just plug it in and check that all the light operate correctly. The adapter should have been fitted and coded.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Help - Need adapter 7 pin to VW tow bar skt
    Sep 2009
    12 Post(s)
    Dam stupid forum double posting, please delete this mods?
  4. Re: Help - Need adapter 7 pin to VW tow bar skt
    Jul 2009
    bath, england
    Thanks for the quick reply. Are you saying that the standard 7 pin plug on the trailer will plug into the 12 or 13 pin socket on the detachable towbar?
    If that is os then I'm a happy camper but I expect the socket will not marry up with the 7 pin plug.
  5. Re: Help - Need adapter 7 pin to VW tow bar skt
    Sep 2009
    12 Post(s)
    Is it a 13 pin socket on the car?
    Well they used to have a 7 pin socket 12N for normal lighting and another 7 pin socket 12S for different features in a caravan (with a white cover) it appears they have combined these two sockets into one.
    Caravan 13 pin Wiring Diagram
    13 Pin Socket
    If your trailer has a 7 pin plug then your going to have to buy a 13 pin plug and wire it as per the link above.
  6. Re: Help - Need adapter 7 pin to VW tow bar skt
    Jul 2009
    bath, england
    I will take a look tomorrow as I need to remove the bumper panel and fit my towbar. I am pretty sure it's a 13 pin, but it's quite a while since I looked at it and have not used the socket yet.
    Thanks for the diagram.
  7. Re: Help - Need adapter 7 pin to VW tow bar skt
    Coventry
    A UK 7 pin plug will not fit in to the new euro 13 pin. You need a spider converter.
    http://www.towequipe.co.uk/itemlist....&submit=Submit
    Specificly this
    http://www.towequipe.co.uk/products/...c-adaptor.html
  1. Golf Mk 6 tow bar
    By dorsetgolf in forum Golf MK6 - 2009 - 2013
    Last Post: 12-11-2009, 05:03 PM
  2. "How To" change Rear Anti-Roll Bar A4 B6
    By willster in forum Audi
    Last Post: 20-10-2008, 12:13 PM
  3. Strange request here, R32 tow bar
    By APRTuned_GTI in forum Chat - Anything with wheels
    Last Post: 17-10-2007, 07:28 PM
  4. vw touran electrical problems tow bar related
    By mark2204 in forum Archive posts
    Last Post: 05-03-2007, 01:57 PM
