Thread: Write protected ECU
Results 1 to 10 of 11
  1. Write protected ECU
    Southampton
    I have a A6 S line special edition 2.0TDI 170, that is three weeks old and have 3500 miles on it.
    I have been told by Evolve that the ECU is mod protected and they cannot do anything yet.
    Does anyone know of someone that can overcome this or anyone that is working on this as I would like to remap as soon as possible.
    Thanks in advance,
    Ian
  2. Re: Write protected ECU
    May 2007
    knee deep in clunge
    14 Post(s)
    do you mean the previous map has locked out or are you referring to the original ecu software
  3. Re: Write protected ECU
    Southampton
    As I understand it the ECU cannot be written to as it is protected from being remapped by the manufacturer, This is a new car registered on the 1st March 2011.
  4. Re: Write protected ECU
    Oct 2010
    Blackpool, Lancashire
    Quote Originally Posted by ianmandlindaf View Post
    True true, Bosch have included anti tuning software on ECU's from approx 59 plate onwards...
    we can get past it, but you would need to remove the ECU and post it to us as the procedure would need to be carried out on the bench..
  5. Re: Write protected ECU
    Southampton
    Quote Originally Posted by protune View Post
    Thanks for the the offer but there is no way I would remove the ECU from the car and post it off, I would be leaving myself open to having a £30k car immobilised and unusable should something happen to the ECU in transit.
  6. Re: Write protected ECU
    Oct 2010
    Well unless you can find someone local to do it, then your stcuk...
    we have about 10-15 ECU's arrive in the post every week, from home and abroad, we ask for them to be posted special delivery with £2500 insurance on them and we return them the same way...
    To date we havent lost any soldiers in this battle..
  7. Re: Write protected ECU
    Oct 2010
    bexleyheath, kent
    Thanks in advance,
    Ian
    Hi Ian
    This is no problem
    Yes it has a tri-core ECU and that will have tuning protections
    We can get past this by programming direct to it
    It does mean the ecu will have to be removed from the vehicle and opened
    but no soldering using alietech tri core programming tool
    David Lewis
    www.flashremapping.co.uk
  8. Re: Write protected ECU
    Oct 2010
    bexleyheath, kent
    Alternatively you could try a tuning box
    Work well on common rail diesel engines
    http://www.flashremapping.co.uk/cms/...asp?iId=FHDHFJ
  9. Re: Write protected ECU
    Southampton
    Quote Originally Posted by FlashRemapping View Post
    Hi Ian
    This is no problem
    David Lewis
    Thank you for your reply, I have been to Revo today and the ECU apparently is a new type that they had not seen before, it is now unlocked and they are writing the program so I will just need to go back in the next few days to have it uploaded to the car.
  10. Re: Write protected ECU
    May 2007
    knee deep in clunge
    14 Post(s)
    can you do me a favour, ask them if uds diagnostic protocol has any bearing in flashing the ecu
    ignore this just asked a friend about it and its nowt to do with uds
  1. Replies: 16
    Last Post: 24-11-2016, 01:28 PM
  2. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  3. ecu re write
    By pabveg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2009, 08:10 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Replacement ECU
    By brendanm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-11-2007, 02:12 PM
