Thread: AVF v AWX vacuum/turbo layout
  1. AVF v AWX vacuum/turbo layout
    Jan 2006
    Near Basingstoke
    what is the difference between these 2 engines and is there any difference in the set up/routing/readings of the various vacuum pipes, solenoids logs etc in relation to the various digrams and pictures on this site. I am trying to get a feel for what everything does, where it is and how it all holds together (thanks Martin as always for your excellent site). As my last Passat was petrol and this is my first ever diesel I am trying to understand what all of the logs mean, how everything works etc. My engineering background talking I guess!
  2. Re: AVF v AWX vacuum/turbo layout
    What do you mean 'Logs' Regards Peter
  3. Re: AVF v AWX vacuum/turbo layout
    Jan 2006
    Near Basingstoke
    VCDS logs, do they have similar characteristics etc. Any main differences
  4. Re: AVF v AWX vacuum/turbo layout
    Gwent
    I think the layout will likely be the same. The AVF gets mated to the 6 speed box which can take more torque, hence the AVF having an extra 20 or is it 25 Nm. possibly achieved by different ECU settings but I could be wrong..
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Re: AVF v AWX vacuum/turbo layout
    Norfolk
    AVF and AWX are the same engine with the same bits and pieces. Same power etc.
    They generally share the same part numbers for the parts.
  6. Re: AVF v AWX vacuum/turbo layout
    AVFAWXCapacityltr.1.8961.896Power outputkW at rpm96/400096/4000TorqueNm at rpm310/1900285/1750 … 2500
    Regards Peter
  1. Important Has a dealer supplied me with wrong oil 1.9 tdi AVF?
    By elite0777 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-12-2010, 05:32 PM
  2. Torque on AWX vs AVF vs AJM
    By itssmail in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2010, 12:03 PM
  3. AVF engine from A4 to A6
    By galleon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-02-2010, 12:33 PM
  4. AWX A6 Cruise control..
    By davebp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-07-2009, 11:08 AM
  5. tdi 130bhp blow which replacement awx or avf
    By jasonsaunders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-05-2008, 07:20 PM
