Thread: Vag Com For macbook pro
  1. Vag Com For macbook pro
    Feb 2009
    hello there guys, what vag com kit would i need to use vag com on my mac and what wires and also where to get them from ? thanks
  2. Re: Vag Com For macbook pro
    Feb 2009
    also, the cars i need to use it on is 2004 audi a4 tdi b6, and 2006 b7 140 (bhp)
  3. Re: Vag Com For macbook pro
    Ambler, PA, USA
    VCDS is designed for Windows based PCs. Some have been able to get the product to run on MACs. Please see the information in our FAQ #1.8
    For your cars, you will need a HEX+CAN style interface to be compatible with both Audis. I would recommend that you go with the USB connection to connect to your MAC - I doubt it has a serial port
    46 Post(s)
    Try seeing if it would run on Paralell or Bootcamp?
    Mar 2011
    Bristol, UK
    It should work under a virtual machine under parallels desktop or VMware fusion. With parallels when you plug in a USB device it will ask if it should be connected to mac or vm (can ask each time or remember), just waiting for my vcds cable to arrive (to confirm myself) but have used superchips bluefin with no issues this way with a windows xp vm, pretty sure.
    Of course safer to use on a pc with no emulation software in the loop, but no similar s/w I've come across for mac.
    Alex
  1. Air Bag Controller 5 Digit Software Code - VAG COM Pro Version
    By puzzlefish in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2018, 05:46 PM
