Thread: 1.9 Tdi wont start
Results 1 to 10 of 12
  1. 1.9 Tdi wont start
    Jul 2008
    Hi there,
    I'm having problems with my car starting, went to start it the other day and it just kept turning over without starting, then the engine management light came on flashing. I got the codes read and it came up with: 16705 ENGINE SPEED SENSOR IMPLAUSIBLE SIGNAL: P03221.
    I spoke to the brother in law and he said he's had a few like this that need a relay changing under the steering wheel, so as I tried turning it over I tapped the relay and it started straight away. I bought a new relay thinking it was that, put it in and its exactly the same.
    Thinking that it was a loose contact I pushed the cables to the relay and now when I turn the key I can hear the relay clicking and the rev counter sporadically moves.
    Anyone had anything like this, and did a new sensor fix it or was it wiring?
    thanks, Scott
  2. Re: 1.9 Tdi wont start
    The engine speed sensor is not controlled by any relay,it is on the side of the engine,check the wiring to the sensor
  3. Re: 1.9 Tdi wont start
    Jul 2008
    Thanks, the relay clicks when I first turn on the ignition and the glow plugs are warming, then once the glow plug light goes out it clicks again, then the relay and rev counter starts going crazy without trying to turn the car over. As you can probably tell I'm a novice at car maintenance, could you give me an idea where the loom is for the sensor and where the sensor is please?
  4. Re: 1.9 Tdi wont start
    I need the engine code then
  5. Re: 1.9 Tdi wont start
    Jul 2008
    How do I find that out?
  6. Re: 1.9 Tdi wont start
    the code is 3 letters abc azf or similar,you will find it in the vehicles serice book,or in the spare wheel well
  7. Re: 1.9 Tdi wont start
    Jul 2008
    I've just checked and its BKC. thanks for your help
  8. Re: 1.9 Tdi wont start
    front rear of the block behind the oil cooler housing
  9. Re: 1.9 Tdi wont start
    Jul 2008
    Are the sensors hard to change do you know?
  10. Re: 1.9 Tdi wont start
    a bit awkward
  1. GOLF GT TDI (150) 2002 Intermittent Poor Start
    By JamesVW in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2010, 04:53 PM
  2. A6 1.9 TDI Warm Start Judders!!
    By mrcheeezy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-11-2007, 03:10 PM
  3. VW Passat 1.9 TDI Start problems
    By alienkidmj12 in forum Passat - Archive Topics
    Last Post: 03-07-2007, 07:10 PM
  4. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
