Thread: Sat Nav No Signal
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Angry Sat Nav No Signal
    Feb 2011
    Lurgan, Co Armagh
    I just bought a 2007 A6 S Line Le Mans Edition.
    I'm having a few probs with the sat nav and a few sites recommended vwaudiforums.
    When I turn on the sat nav it shows my position as France on the screen even though I'm in the UK. There seems to be a destination already in cos when I press the main centre button it starts to navigate back to Ireland?? I have tried to delete the destination but that didn't work. I also noticed that the unit has 0 satellite connections.
    As the car is new to me i haven't a clue what the prob is or
    how to fix it. It's also ourside the warranty so I
    Would like to try and fix it without the need if Audi if possible. So I
    Hope you guys can help shed some light!?
    46 Post(s)
    It sounds like it's in demo mode? Go to nav then hit setup and see if demo mode is enabled. It could also be the drive itself or the GPS aerial.
    Saloon or avant?
    Welcome along
  3. Re: Sat Nav No Signal
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by sitchey View Post
    in the sat nav set up check how many satellites are received
    go into car settings default and then
    carry out mmi reboot with the control panel see here http://a6retrofit.tripod.com/articles/resetmmi.html
    post screen shots if possible
  4. Re: Sat Nav No Signal
    Feb 2011
    Lurgan, Co Armagh
    Hi guys
    Thanks for the replies. I checked and the unit isn't in demo mode. Also can confirm that it's receiving 0 satellites.
    It's weird as while it shows the car being in France when u start driving on a road the nav arrow moves along some French road like it's working!!
    I will try a reset in the morning and will take some pics on the phone
    Anyway appreciate your help with this
    46 Post(s)
    No problem, as A8 says, try a reset and see what happens.
  6. Re: Sat Nav No Signal
    Feb 2011
    Lurgan, Co Armagh
    Hi Guys
    I firstly checked to make sure it wasn’t in demo mode, which it isn’t. I then tried the reset which didn’t work as the unit is still showing as being in France! I also still get 0 satellites being received. I have uploaded some pics to show you as it is driving me nuts!
    I did noticed that when the map is showing and I click the bottom left soft button (Nav-Info) the nice Audi lady says in ENGLISH "Navigation not active" Whats this mean?
    I went into the boot to check the drive and disc. When you press eject the system spits out the disc about 90% of the way, but you then have to really pull hard to get it out. The same thing applies when you put it back in. I cleaned the disc but it didnt help either.
    I think there must be something wrong with the nav dvd drive, however surely even if the disc doesn’t work the system should at least pic your location up and maybe display you on some blank piece of ground??
    Im just a bit worried as I just bought the car and the guy who sold it was a private dealer who wasn’t very technical and doesn’t know what the problem is.
    Any more things i could try?
  7. Re: Sat Nav No Signal
    Feb 2011
    Lurgan, Co Armagh
    Oh forgot to answer A6 Chris's question.... its a saloon
    46 Post(s)
    That's a weird one now. The Nav-info is meant to say that, just means you have no route planned. Mine does it and I'm sure everyone elses does. Could be a dodgy DVD drive, sounds like it. Can you get access to VCDS to get codes read?
    Maybe you could move to France and then your problems would be solved
    A8 - If there was a fault with the drive would it show up on the scan?
    46 Post(s)
    Just wondered because the Avants have a problem where the rear washer leaks and drowns the electrics in that area with water and causes faults.
    What happens if you plan a route?
  10. Re: Sat Nav No Signal
    Feb 2011
    Lurgan, Co Armagh
    If i plan a route it starts the journey from France lol! I am heading to the south of france in a few weeks, but dont really want to take the car on the plane as Ryanair would charge an arm and a leg for the seat lol!!
    What is the VCDS? Sorry for being a nob but this is new to me.
    If the drive is ******, would it stop the system from picking up any satellites?? I thought the drive just read the maps and put a road underneath where the gps said u were
  1. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  2. Sat Nav not working.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-04-2011, 02:19 PM
  3. Question mk 5 sat nav
    By krox in forum Golf MK5 - 2004 - 2009
    Last Post: 14-08-2009, 08:45 AM
  4. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
  5. Anyone trading in a B6 Audi A4 with RNS-E Sat Nav ?
    By Johnboyc in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2007, 04:38 PM
