Thread: Direct Injection - Decoke
Results 1 to 10 of 13
  1. Question Direct Injection - Decoke
    Hi all,
    Previously I posed a question in regard to Catch Cans, with absolutely no response, SO...
    How do you address the problem of carbon buildup behind the inlet valves on direct injection engines ( without dismantling the inlet manifold).
    This appears to be the major liability for direct injection and yet it receives so little if not nil attention on this Forum.
    Searching the US Forums indicates that this is a BIG concern, particularly for Vw and Audi with direct injection. The use of upper cylinder lubricant appears to 'clean' and reduce the incidence of carbon buildup on the inlet valves. A number of threads and photos have been posted, regretably of earlier models, nothing specific to the A4B8 petrol engine.
    I find it hard to believe the A4B8 is not subjected to this carbon problem.
    Your assistance would be welcomed, particularly from the Tech`s who most be aware to this and just how to externally remove and reduce the carbon buildup.
    Regards John
  2. Re: Direct Injection - Decoke
    Jul 2008
    Essex, United Kingdom
    First of all...Im no expert in this, but it reminds me of something I read in Audi magazine recently. It suggested that the quality of fuel is a major factor to this..and they demonstrated in a V8 engine how poor quality fuel results in lots of coking/carbon build up, whereas a good fuel like Shell Optimax/BP Ultimate can help reduce this. I realise this doesn't answer your question..but I thought it might be a useful factor in helping reduce the indicidence of the problem in the first place...stick with a good premium fuel and it may help! As far as I am aware the quality of fuel in Europe tends to be of a much higher standard than that produced in some parts of the USA; giving a cleaner burn and with various additives.
    -Andrew
    1994 VW Polo 1.4L (Scrapped)
    1998 VW Polo 1.4L - Somewhere Out there...
    2004 Audi A4 1.9TD 130bhp <--Gone but not forgotten!
    2011 Audi A4 3.0 V6 TDi 240bhp - Moved on, but still going
    2017 Audi S3 2.0 TFSI 310bhp
  3. Re: Direct Injection - Decoke
    Thank you Andrew,
    Yes I also have read this and have no reason to doubt.
    I am running a 95 octane fuel ( Caltex Australia), and using the correct 504/507 ( from memory) Audi recommended oil.
    The car is relatively new and I can see small oil residue in the breather vent hose ( I expect this to continue, consequently the carbon build up ).
    Regards John
  4. Re: Direct Injection - Decoke
    Jan 2011
    Bucks
    Absolutely right, lower octane fuels don't burn as cleanly. Lived in the US for a couple of years and remember seeing fuel as low as 87RON. Part of the reason US market cars don't perform as well ad European market motors - engines can't be as highly tuned and in any case a low RON fuel will never deliver top performance or MPG, coupled with the fact that the US gallon is smaller than Imperial means comparing fuel economybetween US and European is very difficult. Whoops seem to have gone off topic sorry!
  5. Re: Direct Injection - Decoke
    130 Post(s)
    1972 Post(s)
    It puzzles me how direct injection can have a build up on the back of the inlet valve, indirect never suffered from this so maybe indirect kept the valves clean.
  6. Re: Direct Injection - Decoke
    Jul 2008
    Out of curiosity, do you think the newer generation of TDi engines may suffer from this too? The reason I think that is because as far as I'm aware both the FSI and TDi engines use the Common rail technology concept (i.e. Direct injection). As such, both the engines aren't really that far apart in engineering terms...
    -Andrew
  7. Re: Direct Injection - Decoke
    130 Post(s)
    1972 Post(s)
    I think any build up on a direct injection engine, whether petrol or diesel, must be due primarily to crankcase ventilation fumes and then EGR gases, sticking to the back of a hot inlet valve.
  8. Smile Re: Direct Injection - Decoke
    Dear Crusher,
    With indirect the fuel 'washes' over the inlet valve, direct injection does not hence the build up of burnt fuel/oil vapor.
    I believe diesel direct injection is far worse due to the higher compression ratio ( blowby).
    Regards John
  9. Re: Direct Injection - Decoke
    130 Post(s)
    1972 Post(s)
    Yeh, I kinda know that after 30 years in the trade... My point was that due to direct injection NOT washing the back of the valve, the type of fuel used cannot be the cause for inlet valve deposits and there should be not reversion either, so any build up can only be from what comes down the ports. i.e. crankcase and EGR fumes.
  10. Re: Direct Injection - Decoke
    Dear Crasher,
    That`s right, but after 30 years in the trade how is this carbon build up removed, (without dismantling the inlet manifold ).
    Everyone seems to suggest sucking the upper cyl. lube via a vacuum hose, I am unaware of the correct hose to use on the A4B8 ( CDN petrol ).
    The IAT is mounted directly above the throttle body, I am wondering if this would be an appropriate place to temporarily insert a plastic hose and feed the lube into the inlet manifold.
    It is very interesting to note lots of suggestions, but nothing specific.
    Thank you for your assistance
    Regards John
  1. Please Help Do You have VCDS
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2014, 11:17 AM
  2. Please Help Caddy 1.9 SDi won't start
    By nial in forum The Commercial Range
    Last Post: 30-03-2012, 11:45 AM
  3. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  4. Newbie - first post- looking to buy!
