Thread: problem hazard lights
  1. Exclamation problem hazard lights
    Dec 2008
    Hi all, bare with me this is my first thread. Can anybody throw some light / help to the hazard warning lights on my 2002, A6 2.5 deisel quattro. The near side flashers do not work when the hazard lights are on. They don't flash when the car is locked with the remote. any help would be very useful. Thanks.
  2. Talking Re: problem hazard lights
    Jan 2011
    Bishops Stortford UK
    hi,recently done the same on my 1999 a4 1.8t.Is the hazard light (switch hazard relay)switch on your centre console.It's a common fault on every vagcar.So...what you do is pull the surrounding plastic bit and you should be able to see the switch itself.the switch has 2 clips on each side(lef and right).Someone advised to remove stereo to get to them,but I've done the easiest for me way which is get pliers and pull the damn thing!!!It came out like you open a vine bottle.When it's out you will see the plug at the back of it.Unplug it,plug the new one in and enjoy!!!
  3. Re: problem hazard lights
    Up North
    As escobar says, it's a common problem. So common that your dealer will have a spare in stock and happily take twenty-odd quid for it. It normally affects the flashers first, not the hazards so check that you even have normal use.
    To confirm the problem, you can take the old one out, crack open the lid and clean up the relay contacts with a very fine abrasive. That will give you maybe another 6-12 months of fault free operation, but eventually you'll need a new 'un. When you take it out beware the the leads behind are just a little too short so be careful not to let them drop behind the dash or it will be a radio out job.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  4. Re: problem hazard lights
    Dec 2008
    Sorry for late reply thank you very much
  5. Thumbs up Re: problem hazard lights
    Jan 2011
    No probs.I am glad to hear that the problem has been solved.Regards!
  1. Dash problem? No reverse lights?
    By shane14 in forum Touran - Sharan - Caravelle
    Last Post: 09-08-2009, 04:36 PM
  2. hazard light and indicator problem
    By unnikuttan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2008, 02:32 PM
  3. courtesy lights problem
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2008, 12:16 AM
  4. Interior lights problem
    By robby71 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-12-2007, 12:08 AM
  5. 1999 SE Avant - problems with dashboard lights
    By Adam&Eve in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2007, 12:20 AM
