Thread: A4 B7 B Pillar Trim removal?
Results 1 to 10 of 12
  1. A4 B7 B Pillar Trim removal?
    Jan 2011
    Kent, England
    Hi all... Got a question.. Ive Been trying to remove the B pillar interior trim were the seat belt comes out of and just cant get it to come off.. is there a thread for this or dose anyone now how to do it, i dont want to start pulling on it and break it..
    I need it off to get the trim below it off so i can run a power wire down the edge of the floor.
    I have searched but cant find anything
    my car is a 2006 B7 2.0T SLine..
    Thanks in advance
  2. Re: A4 B7 B Pillar Trim removal?
    Coventry
    I fed a loom rear to front, didn't remove anything forward of the rear seat except the glove box. See if the reversing camera how to guide will help you. I just tucked the wire/loom under the edge of the plastic trim.
    https://www.vwaudiforum.co.uk/forum/s...8&postcount=13
  3. Re: A4 B7 B Pillar Trim removal?
    Jan 2011
    Kent, England
    Quote Originally Posted by Ben View Post
    Ok thanks
    so do you think i will just be able to tuck the wire under the trim, it is quite thick as its for an amplifier (i do like my bass)
  4. Re: A4 B7 B Pillar Trim removal?
    Coventry
    If in doubt, I think the plastic trim across the bottom of the doors is just held by large clips that will prang out. There maybe a screw on the front one on the inside by the bonnet pull area. As you have read, I didn't remove mine. With regard to b pillar, I think you have to start at the bottom and work up. I think there is a kind of overlapping system I think, remove the door trim, then the bottom panel of the b pillar. You may also have to remove the bottom edge of the rubber door seal.
    Of corse, I could be completely wrong.
  5. Re: A4 B7 B Pillar Trim removal?
    Jan 2011
    Kent, England
    Ok i will give it a go, if its just clips i might just have to pull a bit harder..
  6. Re: A4 B7 B Pillar Trim removal?
    Coventry
    try these
  7. Re: A4 B7 B Pillar Trim removal?
    Sep 2008
    it's pretty easy, done it a couple of times recently. to get the lower one off you need to take the top one off as it overlaps. the top one pulls towards you, the lower one needs pulling away from the pillar but also towards the roof of the car as the lower clips slot downwards into the floor
    trickiest bit is putting them back on! especially the top one, I found the seatbelts caught up and had to take them off again and have another go
  8. Re: A4 B7 B Pillar Trim removal?
    Jan 2011
    Kent, England
    Ok briliant thanks for the PDFs Ben,
    I have tryed again today and just cant get it off, it os soooo tight on there.. i was pulling as hard as i could and it was not moving?
    Is there a certian technique to it?
  9. Re: A4 B7 B Pillar Trim removal?
    Coventry
    Quote Originally Posted by phil. View Post
    Get a firm grip, pull hard but not suddenly. Whilst doing this repeat to yourself 'please do not break, please do not break'.
  10. Re: A4 B7 B Pillar Trim removal?
    Sep 2008
    That's the technique. I took flat screwdriver, stuck it in just above bottom edge of top trim, on the sides. Prised it away slightly so could get fingers in and pulled firmly but slowly. They are held at bottom by those metal pins/clips if I remember correctly
  1. Please Help Avant tailgate trim removal
    By Dave Gee in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2016, 04:33 PM
  2. Replies: 4
    Last Post: 09-01-2010, 08:18 PM
  3. Pricing Set For Uk-bound Audi Tts Coupe And Roadster
    Last Post: 13-02-2008, 08:03 PM
  4. A4 B5 Avante door trim removal
    By deano2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-06-2007, 08:52 PM
  5. New Audi A4 Cabriolet 2.0 TDI Ticks all the Boxes
    Last Post: 09-10-2005, 12:37 PM
