Thread: Sharan. Can I lock my doors without activating the alarm
Results 1 to 10 of 10
  1. Sharan. Can I lock my doors without activating the alarm
    Nov 2010
    Sunny lancashire
    I lock my car with the remote which sets the alarm and locks all the doors. Great, but when I have the dogs in the back, and lock the car with the remote, the dogs keep triggering the alarm.
    Is there any way I have my dogs in the car with the doors locked without the alarm keep going off??
    Thanks muchly
    Oct 2010
    Here And There
    Hi there, as far as I know, you can turn off your movement sensors in the car before setting your alarm. I could be wrong here but I think you will find a very small button with wavey lines on it on the bottom of drivers side "A PILLAR" trim. Before getting out, press that button and then lock your car as normal. The movement sensors will be off so Rover and Fido are free to eat your seat belts without the alarm triggering
    Sent from my iPhone using Tapatalk as I cant be ***** turning on my laptop !
  3. Re: Sharan. Can I lock my doors without activating the alarm
    On 2004 Alhambra you deactivate internal sensors by locking with the key, turn key to lock position, c/l will activate and door led flashes. Turn key to lock position a second time immediately. Internal sensors de-activate and LED stops flashing to confirm. Don't hold key in lock position for more than a fraction of a second though or any windows left open for ventilation will auto-close
  4. Re: Sharan. Can I lock my doors without activating the alarm
    Nov 2010
    Sunny lancashire
    Quote Originally Posted by matthewgdavies View Post
    Thanks for this. I'll have a try with the door key, and see what happens
  5. Re: Sharan. Can I lock my doors without activating the alarm
    Nov 2010
    Sunny lancashire
    Quote Originally Posted by Bangor Lad View Post
    Thanks for this......but what is puzzling me is how you know my dogs names
    Oct 2010
    Here And There
    Quote Originally Posted by sharansporttdi View Post
    Well it was a guess of that or sooty and sweep
  7. Re: Sharan. Can I lock my doors without activating the alarm
    Jun 2009
    86400 St Macoux, France
    easy -- double make sure your have the key then reach through via drivers side rear door and push internal door handle in on drivers door. Then just close the osr door and car is locked , no alarm. Unlock as normal ( in my case always with key as remote has never worked)
  8. Re: Sharan. Can I lock my doors without activating the alarm
    Nov 2010
    Sunny lancashire
    Quote Originally Posted by DAVE ROBINSON View Post
    Sounds like a plan
  9. Re: Sharan. Can I lock my doors without activating the alarm
    Nov 2010
    Sunny lancashire
    This seems to work for me.......unless the dogs are just lying still
  10. Re: Sharan. Can I lock my doors without activating the alarm
    Jul 2009
    Lancs
    Double press on the remote works for me. You press it twice within a second of each other. The light on the door that flashes, stops flashing indicating that the interior sensor is switched off.
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. Trying to lock my A6 without setting the alarm (faulty door microswitches)
    By wydths in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-02-2011, 10:41 AM
  3. New sharan debuts at the geneva motor show
    Last Post: 02-03-2010, 08:47 PM
  4. New sharan debuts at the geneva motor show
  5. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
