Thread: A4 Turbo, no boost
  1. A4 Turbo, no boost
    Jan 2011
    Burton On Trent
    Hi, I used to have a TT, and you could hear and feel it when the Turbo kicked in. I have just bought a A4 1.8T (2003) Engine code BFB, and does not seem to have any boost. There are no codes recorded, and not indicating it is in limp mode. Would appreciate a few pointers to look at please.
    Would have expected a ECU error code if the turbo is not working. I have not changed any parts yet, but hope the turbo has not gone!
    No abnormal smoke from the exhaust.
    Any thoughts would be much appreciated!
    Thanks!
  2. Re: A4 Turbo, no boost
    Jan 2009
    Im certainly no expert mate but a wire came loose on my map sensor and there was no boost. I also took a few things out to clean before and put a pipe back in the wrong place and no boost. Have you done anything with the car lately
    A4 Quattro 1.9 tdi
  3. Re: A4 Turbo, no boost
    Jan 2011
    Burton On Trent
    Thanks for the reply!
    The only thing I have done is replace the coolant flange, but dont think the boost was there before I did that. Is it your MAF sensor that had the loose wire? I have also plugged into the ECU for error codes, and there are non?
    Not sure if you can see the live boost pressure, or do some test to see what it is?
    I will make a start as you say and check the pipes and connections to the Turbo, and see if anyone else has had a similar problem to you, but will check the sensor. Thanks for your help!
  4. Re: A4 Turbo, no boost
    Jan 2009
    Quote Originally Posted by abbsy3 View Post
    No it was a loose wire on the map pressure sensor worth a look anyway
    A4 Quattro 1.9 tdi
  5. Re: A4 Turbo, no boost
    Sep 2008
    Could be a sticking actuator arm keeping the wastegate open, that would allow all the boost to escape.
  6. Re: A4 Turbo, no boost
    Ireland
    You can test the turbo if you have VAGCOM or VCDS.
    you need to map some variables on VAG Scope.
    Below link should be helpful.
    https://www.vwaudiforum.co.uk/forum/s...d.php?t=105813
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  1. 1.9 tdi 110hp power upgrades
    By G-sport in forum Archive posts
    Last Post: 19-01-2008, 01:50 PM
  2. Audi A4 1.9tdi lack of turbo boost
    By DRCDG in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-07-2006, 01:07 PM
  3. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  4. Audi A4 1.9tdi lack of turbo boost
    Last Post: 12-06-2006, 11:11 AM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
