Thread: Wheels offset
  1. Wheels offset
    Jun 2009
    Bromley, Kent
    Hello everyone
    I know the factory fitted 18" wheels have 43mm offset and I am planning to fit 18" with 35mm offset. Does anybony know will it be a problem and do I need some spacers as well?
    Thank you
  2. Re: Wheels offset
    Bratty Guest
    If you are getting 18 inch wheels with the same width as the ones you have already (ie.8J) you will just be moving the outer rim 8 millimeters futher out from the axle. That is "WELL" within reason.
    There is a wheel offset configurator "Linky" somewhere on the Forum.
    Dunk
  3. Re: Wheels offset
    Jun 2009
    Bromley, Kent
    Quote Originally Posted by Bratty View Post
    Dunk
    Thank you Bratty, just spent 15-20 minutes in the web and found a very good calculator.
    So I am ok with them
  4. Re: Wheels offset
    Nov 2010
    Yorks, UK
    Standard A4 B8 wheels:
    7J x 16; ET 39 205/60/16 92H
    7.5J x 17; ET 45 225/50 R17 94Y
    8J x 18; ET 47 245/40 R18 93Y
    8.5J x 19; ET 43 255/35 R19 96Y
    112 PCD 66.56 bore
  5. Re: Wheels offset
    Bratty Guest
    Quote Originally Posted by Zafi View Post
    112 PCD 66.56 bore
    Good Info Zafi. I think the thread topic is asking "What happens if I drift away from Manufacturers recomended "Suggested Offsets"? And that takes a bit of digging!
    I can say that from experience 9JX19;ET 35 255/35 R19 from an A5 will fit on an A4 B8, But the front axle combo is extremely close to the sensible limit!! And I would say that in hindsight I would not go more than 8.5JX19;ET 35 with the same tyre on the front axle (on the back I had NO! probs with the 9J but then again I am not exactly a Caravan Towing Type.
    Dunk
  6. Re: Wheels offset
    Nov 2010
    London
    I run 18 x 8.5 ET35 BBS wheels for my winter wheels without problems on a 2.0tdi Quattro Avant
  1. OFFSET & PCD - What other wheels fit in the VAG range ?
    By RickT in forum Golf MK5 - 2004 - 2009
    Last Post: 12-11-2010, 02:25 PM
  2. offset of SLINE wheels
    By jonathon555 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-06-2009, 08:57 PM
  3. 17" Mk1 Audi TT Competition polished wheels - offset needed
    By unclefester in forum TT - 8N Forum - 1998 - 2006
    Last Post: 28-02-2008, 10:01 AM
  4. How does the Quattro system work?
  5. Insurance & Modifications ££££££
    By torrox in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-05-2007, 07:39 PM
