Thread: Changed brake pad now ABS and ESP light are permantly on? Please help!
Results 1 to 10 of 19
  1. Changed brake pad now ABS and ESP light are permantly on? Please help!
    Jun 2009
    Edinburgh
    Hi there,
    I have changed the brake pads on my A4 tonight and now my ABS and ESP lights are permantly on. Has anyone got any ideas what this could be please? Or is it the case of a simple reset after changing the pads and pad sensors?
    Thanks very much
    Kyle
  2. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    Sep 2008
    chester
    17 Post(s)
    You've most likely dislodged one of the abs sensors around the hub,they're quite sensitive,take the wheels off and check the air gap between the sensor and its pick up ring around the hub,you may need a scan to determine which one is faulty.
  3. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    Jun 2009
    Edinburgh
    Thanks for that! Is it likely the ABS sensor will be damaged or just dislodged are the delicate? What should the gap be please?
  4. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    130 Post(s)
    1972 Post(s)
    Have you taken it for a drive yet?
  5. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    Jun 2009
    Edinburgh
    Yes taken it for a good 20 minute drive still the same issue. Any ideas?
    Thanks in advance
  6. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    Sep 2008
    chester
    17 Post(s)
    Check for any fault codes,make a note of any and delete,see if any return.
  7. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    Jun 2009
    Edinburgh
    Thanks guys getting my car plugged in tonight will make a note of any codes and see if they return! Thanks for your help its appreciated will let you know how i get on!
    Thanks again
  8. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    Mar 2008
    High Wycombe
    If it's being plugged in, you can use measuring blocks in the ABS module to show all four wheel speeds as you drive slowly (upto 10 mph) in a straight line. If one is different to the others, that'll be the faulty one. The ABS module picks this up as a fault.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  9. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    Jun 2009
    Edinburgh
    So then ... time for an update,
    Plugged my car in today and a fault came up with the front right ABS/speed sensor, seems like an easy fix thank god. So im thinking for the sake of 50 quid just replacing it to solve the problem. But before i do does anyone know if it could be anything else other than a knackered sensor?
    Thanks for all the help!
  10. Re: Changed brake pad now ABS and ESP light are permantly on? Please help!
    130 Post(s)
    1972 Post(s)
    It could be a broken wire.
  1. Audi A6 3.0 Tdi Quattro - esp light
    By gasc2188 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-01-2011, 01:57 PM
  2. ESP, ABS and Heater Plug Light
    By PassSPORT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-12-2010, 11:58 PM
  3. How To ABS + ESP + glow plug light flashing
    By Camb-Tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2010, 05:56 PM
  4. Please Help Passat 2.0S 2002 Brake Lights and Flat Battery with intermittent ESP / ABS warning light
    By tweever in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2009, 01:50 PM
  5. ABS and ESP Warning Light Illuminated after Pressing Brake Pedal
    By Tub Thumper in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2008, 09:50 PM
