Thread: Mk4 glow plug light flashing
Results 1 to 8 of 8
  1. Mk4 glow plug light flashing
    May 2010
    Blyth northumberland
    Hi just sorted my car out with the no start problem (replacment starter motor) how ever the heater plug light has started flashing since then any ideas?
  2. Re: Mk4 glow plug light flashing
    Southampton, UK.
    Check your brake lights - do all three work? Oddly, the flashing glow plug light can be due to a faulty brake pedal switch.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: Mk4 glow plug light flashing
    130 Post(s)
    1972 Post(s)
    Otherwise you need a fault code read.
  4. Re: Mk4 glow plug light flashing
    May 2010
    yep all brake lights work, but still have the flashing light. i have a vagcom lead i bought off e-bay last year but have upgraded my laptop and didnt down load vag com until yesterday with the new vcd programe i cant seem to get it to connect through my lead so i am assuming the new version wont support my old interface lead.... any suggestions?
  5. Re: Mk4 glow plug light flashing
    Southampton, UK.
    For non-RossTech leads, ie. no-name eBay ones, you have to use the VCDS-Lite version. More info here. I'm still on the old version for dumb interfaces (409.1), so can't help you more on the new one. I assume the drivers for the lead are installed ok?
  6. Re: Mk4 glow plug light flashing
    Southampton, UK.
    There is a specific section where you can post your VCDS question. See here.
  7. Re: Mk4 glow plug light flashing
    Mar 2007
    coventry
    hold on car was fine before battery change and starter motor change ie no light flashing ?
    check all the wires are fitted correctly and good contact also just check all the fuses hopefully helps fella
    rich
    no matter how you try you always come back to what you first started
  8. Re: Mk4 glow plug light flashing
    May 2010
    Sorted got my cheap lead and vag com lite to work whoop whoop will post how i did it on another thread when i have got time ....... ok checked vagcom and the reason the glow plug light was flashing is because the imobiliser stopped the engine from starting reset the fault code and bingo no more flashing light on the down side though i have a duff abs sensor on the front lol oh well here we go again
  1. caddy glow plug/brake light problem
    By bruwalsh in forum The Commercial Range
    Last Post: 24-02-2011, 12:00 PM
  2. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  3. transporter 2.5tdi 2003 glow plug light not staying on?
    By vanrental in forum The Commercial Range
    Last Post: 09-06-2009, 04:44 PM
  4. Delay in glow plug coil light coming on.
    By VW driver in forum Chat - Anything with wheels
    Last Post: 12-10-2007, 10:57 AM
  5. Glow plug warning light flashing.
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 06-07-2007, 07:37 PM
