Thread: Vibration after 40mph after hitting kerb
Results 1 to 10 of 11
  1. Vibration after 40mph after hitting kerb
    Dec 2006
    Hi All, I recently hit a patch of black ice and kerbed my driver side wheel quite hard although i was only going about 15mph.My alloy was scuffed quite badly.Since the accident i have had a vibration when i get to about 40mph.I had the alloy repaired today and balanced which i hoped would cure the problem but unfortunately its still there.Any help or advice to what damage i could have done would be very much appreciated.
  2. Re: Vibration after 40mph after hitting kerb
    May 2010
    Devon England
    sorry to hear your problem, if the wheel balanced ok then first off id try putting it on the rear and see if it makes a differece if not id then check the bottom ball joint for play aswell as the TRE and rack, if all appears good id then have a good look at the bottom arm and mounts if all still seems ok iwould check the top mount hope this helps bud
  3. Re: Vibration after 40mph after hitting kerb
    Dec 2006
    Thanks for your help, i have booked my car in to have the tracking checked next week, could this cure the problem? As you may have already guessed i dont know too much about cars.
  4. Re: Vibration after 40mph after hitting kerb
    May 2010
    Devon England
    it could be the tracking but id be checking the whole front suspension first, i would also try swapping the wheel with the spare to see if the vibration goes, if it does go then its down to the wheel being bent
  5. Re: Vibration after 40mph after hitting kerb
    Dec 2006
    To be honest i have been drivng with my space saver for a day whilst my alloy was repaired and although i couldnt drive over 50 mph i did think that the vibration had gone with the space saver on.If the wheel is bent wouldnt they have picked this up when it was balanced after repair?
  6. Re: Vibration after 40mph after hitting kerb
    May 2010
    Devon England
    They should but it can be missed, also a wheel can be balanced but still be off, if you get my meaning, if with your space saver on it drove fine then i would say its the wheel at fault mate, you could try putting the repaired one on the rear so you have a good one on the front and see if that makes any difference, sometimes a buckeled wheel on the rear behaves better than if its on the front
  7. Re: Vibration after 40mph after hitting kerb
    Dec 2006
    Ok i will swap it on the weekend and see how it goes.Thanks for all your advice its been i great help.
  8. Re: Vibration after 40mph after hitting kerb
    May 2010
    Devon England
    Anytime mate
  9. Re: Vibration after 40mph after hitting kerb
    Dec 2006
    Cheers, will let you know how i get on next week
  10. Re: Vibration after 40mph after hitting kerb
    Dec 2006
    Had the tracking checked and suspension and all was ok.Had both front wheels rebalanced but i still had a slight vibration,Swapped the front wheel for the back and this cured it.
    Thanks for all your advcie mate.
  1. 2007 A6 2.0 TDi SE Vibration @ 80 mph
    By pooleton in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-03-2010, 08:28 PM
  2. Kerb weight changes for Golf 2.0 TDI
    By Bogester in forum Golf MK6 - 2009 - 2013
    Last Post: 27-02-2010, 02:54 PM
  3. Question Vibration
    By jgoodman00 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-11-2009, 06:05 PM
  4. More dreaded vibration!
    By Amigo75 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2008, 02:14 PM
  5. Steering light after hitting kerb
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2007, 07:11 PM
