Thread: Compression Test Results
  1. Compression Test Results
    Nov 2010
    Inverness, Highlands
    Hi Guys,
    I have a 95 Coupe 2.0e ABK. The head gasket was leaking when i got it so i rightly or wrongly put in some KSeal in the meantime until i could afford the time and money to do it properly. It actually worked a treat and now runs fine, but i always wanted to do a compression test to check as the mayo is still present on the filler cap.
    Got round to it today, im classing cylinder 1 as the one closest to the radiator;
    1. 110
    2. 105
    3. 115
    4. 120
    Any thoughts on the readings, good or bad? There seems to be very little data available for this engine, what should the results be?
    The car only gets used for a six mile round trip each day, ive done 400 miles in it in 3 months, which i suppose doesnt help?
    Any thoughts would be appreciated.
  2. Re: Compression Test Results
    Pembrokeshire
    22 Post(s)
    not a million miles out. compression test results are better the closer the figures are, rather than what they actually are, especially on an older more worn engine. sounds like it just needs a good italian tune up really.
  3. Re: Compression Test Results
    Nov 2010
    As in a good thrash or a long run?
  4. Re: Compression Test Results
    Pembrokeshire
    22 Post(s)
    as in bouncing off the rev limiter in every gear, wheels alight, engine screaming, blow the cobwebs out sort of driving. get rid of all that coke in the inlet ports, burn the carbon out of the exhaust, for as long as possible. my coupe 16v ace, get driven like this everytime it goes out, and loves it. but do it with clean oil and a good cambelt.
  1. Compression test results - new engine?
    By Rutland Gizz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-12-2009, 10:04 PM
  2. Compression test results - skim head?
    By Rutland Gizz in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 15-12-2009, 12:24 PM
  3. Passat B5 Compression test
    By spitss1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2008, 06:06 PM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. Funny compression test numbers and questions about a head gasket change
    By helium4amc in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-07-2007, 01:14 PM
