Thread: Alhambra Electrical Problem
  1. Alhambra Electrical Problem
    Dec 2010
    Northampton UK
    Our Seat Alhambra 05 plate Diesel TDi lost all electrics. We replaced the battery and alternator and it was ok for 2 weeks. Then the alternator light started coming on again, and now it won't power any of the major electrical items such as heated seats, windscreens, etc the voltage on the meter in the car drops as soon as you switch anything on. Can anyone help?
  2. Re: Alhambra Electrical Problem
    For some reason the alternator is not charging properly,check the terminals on the alternator,to make sure the nuts are secure
  3. Re: Alhambra Electrical Problem
    Jan 2009
    towcester northants
    did you replace the alternator pulley?
  4. Re: Alhambra Electrical Problem
    Dec 2010
    Northampton UK
    I don't think the mechanic did. Would that make a difference? He is worried that the ECU has gone. Thank you for replying by the way.
  5. Re: Alhambra Electrical Problem
    Dec 2010
    Northampton UK
    Hi Kennet, thanks for your reply. i didn't change it a local mechanic did. Much too cold and complicated for me to consider it, although as he says it does look quite accessible. He is worried that the ECU is playing up?
  6. Re: Alhambra Electrical Problem
    Jan 2009
    towcester northants
    unlikely its ecu
    check to see if youve got ignition feed at blue wire at back of alternator
    check to see what voltage alternator is charging at large 13mm bolt terminal should be approx 14volts
    check to see if any faults show up on diagnostic scan as you have a central electrics controller under dash
  7. Re: Alhambra Electrical Problem
    Dec 2010
    Northampton UK
    Hi Kenney,
    Apologies for the delayed reply and the mis-spelling of your name before! The mechanic changed the alternator again on xmas eve and it does appear to be working fine now. Obviously the recon alternator was playing up. Thank you very much for your help with this,
    Rich
  1. Audi A4 cab multitronic problem
    By pickering01 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-03-2011, 04:38 PM
  2. Electrical problem. i bet nobody faced such a problem
    By hamma in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 14-12-2010, 05:22 PM
  3. Please Help 53 Alhambra SE TDI 130 Electrical Problem
    By John Hume in forum Alhambra
    Last Post: 01-11-2010, 09:27 PM
  4. Alhambra electrical gremlins on the loose!
    By emmbeedee in forum Alhambra
    Last Post: 13-08-2009, 07:23 PM
  5. Golf 1.3 cl 1988 engine electrical problem?
    By Nelson in forum Archive posts
    Last Post: 30-09-2006, 12:04 PM
