Thread: brake warning light on dash
  1. brake warning light on dash
    Mar 2008
    Preston
    hi i just bought a audi a4 avant on a 54 plate. the yellow brake warning light is on the dash and wont go off. i have checked the car on vag com and its clean. no faults come up
    the car has just been fitted with new pads on the front by the previous owner.
    i have checked the sensor wires they are all fine. and the brake fluid is good as well.
    what can it be??? after looking at other threads on this forum i come accross one that said it can be low battery, but the fires up strtaight away, but the wipers are very slow moving when i put them on.
    can it be the battery??
    thanks
  2. Re: brake warning light on dash
    The yellow light is the pad warning. Double check the connectors and wires, pull the connectors appart and make sure none of the pins are bent. Are the pads genuine or aftermarket? It could be a faul in one of the pads.
    If it was the battery you would normally get the red light and 3 beeps when starting the car, this would go out straight away. This happens because the ABS controller reads the voltage as being to low.
    You could get the battery drop/load tested for piece of mind, most places wont charge for it (I gues since they hope they can sell you a new battery). Think ********* do it.
    If your wipers are acting slow as well you could have an earthing problem.
  3. Re: brake warning light on dash
    The brake pad warning is designed on a circuit of a single wire from the dash, round each brake pad and back to the dash. If that wire is either broken (worn through/cut) or complete but shorted to earth (pad worn through and wire touches brake disc) the reference voltage will not arrive back at the dash and the warning lamp will come on.
    Re-check there are no parts of the sensor cables are worn through where they could short out. Also check the plug couplers to the sensors; if there is a bit of dirt or corrosion in there it will also give a false indication - for the reasons I've mentioned above.
    MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
  4. Re: brake warning light on dash
    West Yorkshire
    I'm pretty sure i've read that the wipers are known to seize up on A4's, so perhaps a removal and grease of moving parts etc before they seize completely and need new wiper motors?
    Just a thought.
  5. Re: brake warning light on dash
    Mar 2008
    Preston
    Thanks guys, I will check the wires first and then go through other checks, Im did notice that when the battery on a audi goes flat it brings loads of random lights on dash.
    Will post a update of the situation shortly
  6. Re: brake warning light on dash
    Mar 2008
    Preston
    i have still not had a chance to look at the brake pads due to the severe weather conditions.
    but i did notice sometimes when i star the car no warning light come on for the brakes but as soon as i set off the brake warning light comes on
    any ideas???
    thanks
  1. Brake Warning Light
    By Wolverine77 in forum Touran - Sharan - Caravelle
    Last Post: 04-09-2009, 04:51 PM
  2. Brake Warning Light On
    By vtskier in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2008, 09:27 AM
  3. Brake fluid warning light with ABS light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-04-2007, 03:28 PM
  4. A4 Brake System Warning Light
    By lastyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2007, 12:38 PM
