Thread: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
Results 1 to 10 of 20
  1. DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    Wednesbury
    What to do ?
    DPF warning light came on, so I followed the handbook instructions
    and took the car on a long run, after circa 50 miles the engine
    management system warning light also came on and the engine went in
    to limp mode. Staggered home and booked car in to garage.
    The garage were also unable to regenerate the DPF and say that it
    needs replacing. They confirmed that the engine management warning
    light is being triggered by the back pressure in the system
    affecting the exhaust and turbo as a result of the blocked DPF.
    I know replacement of the DPF is not cheap (waiting for a price),
    however I have found a number of companies that offer to remove the
    DPF and configure the ECU and tuning to work without it, i.e.
    1. ECU Programming to ensure the car will run correctly without the
    filter(no errors, no limp mode).
    2. Diesel Injection Tuning to ensure the vehicle will pass it's MOT
    test -
    3. Physical DPF removal labour..
    Would appreciate any advice and guidance that helps my decision, replace or remove ?
    Car is out of warranty
    110,000 on the clock
    Recently had engine rebuild after oil pump failure !
    Love the car just want it to work reliably !!!
  2. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    Jun 2010
    gosport UK
    Does the A4 2.0 TDI 140 have a DPF?
    I was told it does not have one.... Do you mean the Catalytic converter?
    Or have i got it all wrong. Intially i made enquiries as i had read removal of the DPF also helps performance, but when i enquired further about a replacement pipe i was told it was only the 170 model that had the DPF.
    I would like to know more?
    If its the Cat, these guys are local to you and they did fantastic service on new exhaust for mine at a fraction of dealer prices and i know the do custom cats aswell.
    http://www.mijexhaust.com/product-and-services.html
    Not quite the answer your looking for but hope it helps
  3. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    Wednesbury
    Not sure when they started fitting them but there is definitely a DPF on my A4 140.
    The Diesel Particulate Filter is some sort of 'envrionmental' add on.
    Will check out the link you supplied anyway, thanks.
  4. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    May 2007
    knee deep in clunge
    14 Post(s)
    follow this http://wiki.ross-tech.com/wiki/index...y_Regeneration
    check the ash/soot content before and after
    check the clutch switch is working
    check the dpf pressure sensor is reading correctly
    clean out dpf piping
    check dpf temp sensors ar working
    check the valve timing is correct mvb 04 zone 4
    check for excess soot in fuelAttachment 9829Attachment 9830
  5. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    Dec 2009
    Wanstead, London
    The 170's have DPF's fitted from factory.
    In the early days of the 140 bhp 2.0 TDI lumps, it was a optional extra (Free i may add irrc) to add a DPF to the engine and some weirdo's must have asked for it.
    I'd say Remove the sucker and remap it. You'll LOVE the new power of the car.
  6. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    May 2007
    knee deep in clunge
    14 Post(s)
    You cant just remap it, you need to run dpf off program first as dpf is linked to nearly all ecu settings.Find a good remap company who understand this and offer a solution to remove the filter as well
  7. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    Dec 2009
    Wanstead, London
    Of course, i meant to say remove the DPF and all software in relation to the DPF and then remap it.
    AMD and the likes can do it i think!
  8. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    Wednesbury
    Okay time marches on, and after circa 6 weeks with a DPF/Turbo specialist the car has been returned to me, while away it has had -
    DPF removed and engine remapped as required
    The turbocharger rebuilt
    The intercooler removed cleaned and refitted
    Change of Oil and Oil filter
    The turbo still does not work !!!
    I'm told that no error messages are appearing when on the electronics test rig and everything looks fine, the turbo runs fine on a test rig.
    The car drives okay with no warning messages on the dash but is of course underpowered and sluggish as the turbo does not operate.
    The specialist has run out of ideas and is recommending it goes to a Audi specialist for further investigation.
    What I need is help !!!
    Can anyone recommend a Audi specialist (West Midlands based and preferably not a dealer) who should be able to sort this out ?
    Can anyone recommend anything that will bring this horror story to an end ?
  9. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    Wednesbury
    Hoorah, horror story over.
    VWRescue in Wombourne/Wolverhampton finally resolved the issue.
    Turbo now works fine, and an MOT aswell.
  10. Re: DPF Replace or Remove ? - A4 Convertible 2.0Tdi 140 (2006)
    swindon uk
    What was the problem in the end?
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. 2006 A4 Saloon S Line 2.0tdi 170bhp
    By stinkerpuffit in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-08-2010, 08:17 PM
  3. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  4. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
