Thread: PO122, PO222, Throttle Position Sensor
  1. Exclamation PO122, PO222, Throttle Position Sensor
    Dec 2010
    Cpaitol Heights, MD
    Throwing codes PO1222, PO2222. I am having this issue also. I have replaced the TPS with same OEM. I am stuck. Hard start, when it does start. Sometime (most of the time) it cranks and then shakes like Elvis, (younger Elvis). Sometimes it has a hard idle when it's running. Idle up and down all over the place. Then at time it's smooth like we like. She'll run for about 25-30 minutes then out comes the shakes.
    I have done the throttle body adaption and it works to get the idle steady. How ever it goes to EPC light, ABS light, check engine light and then loses power. Sometimes at acceleration sometimes just babying the pedal. At times my Vag tells me 300 series which is random misfires on crazy idle shake land. Then once I turn her off and start her back up ALL codes are gone, until she shakes, rattles and rolls.
    "Were Do We Go Now?"
    What has been done in the last month on 2003 1.8T Q 105K driven less than 100 miles since.
    OEM fuel pump
    OEM fuel filter
    OEM fuel pump relay
    OEM Bosch O2 sensors bank A and B
    OEM Bosal Cat convert
    OEM Purolator Air Filter
    OEM Throttle Position Sensor
    OEM Silver Star Battery
    OEM Spark plugs
    OEM Coil Pack ( new Hitachi revision)
    Cleaned:
    Injectors, throttle body, Inlet hose, Intake hose, MAF sensor, have plans to Seafom the manifold, and fuel line, then change oil and filter.
    What haven't I done that nedds attention?
  2. Thumbs up PO122, PO222, Throttle Position Sensor
    Dec 2010
    Cpaitol Heights, MD
    Well here we go. 5:30 25 degrees the car starts with one turn. Runs a little rough but then smoothes out. I drive less than 10 miles return trip, everything seems normal. No DTC or CEL. Nice, but I need to have some one with Audi knowledge look under the hood.
    In my area there is NO ONE that is competent enough that understands the rings. Furthermore it just sounds like a real, real bad idea.
    Example: On first break down, had car towed to local shop for diagnosis. As I was waiting with full attention on "*** just happened to my car?" I kept watching the garage mechanic trying to unlock the passenger side door, "WITH THE KEY" Hum . . . And when I asked him what he was doing, he said, "Did you know they forgot to put a door lock on that side of the car." I had to ask them to "please stop now" and tow it to my residents. I was sick for the rest of the day.
    The car always shuts down before I can even think about getting her close to the highway to get her to the dealership for a check up. I am hoping that the codes will not return. yea Right!. I don't have a vag com I have a basic cheap-o from Advanced. Actron CP0125 OBD II Code Reader/PocketScan.
    All the repairs were made by me done while using this forum,a lap top and make it happen. Major major savings. But I still need the details. The Audi tech details like what has to be done also like, ECU reprogramming? and maybe a chip for better performance? Please feel free to provide any feed back. All feed back is welcome.
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. Throttle control problems with 2.6 V6
    By McSam in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2014, 01:24 PM
  3. A4 B5 throttle body reset problem with VAG
    By adrianwillis in forum VCDS - General Questions
    Last Post: 09-09-2011, 12:12 PM
  4. Question Help Please Polo 1995 1.0 idle issue
    By neokuli in forum Polo - Derby - Lupo - Fox
    Last Post: 25-09-2010, 08:14 PM
  5. Mk3 Golf TDI throttle position sensor
    By j_coupland in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2006, 05:09 PM
