Thread: A4 Avant B7 Front Suspension Problems!
  1. A4 Avant B7 Front Suspension Problems!
    Oct 2009
    Cambridgeshire, UK
    Hi, ive got an A4 2.0tdi B7 Avant with a knock on the front suspension. Its a small rattle when i go over holes/dips at low speed but can still be lightly felt through the car at speed also.
    I have recently had the steering rack and track rod ends replaced under warranty and the bottom arms both sides were also replaced so i know it can't be these that are at fault. I have jacked up the car and checked the top arms and can not see or feel any movement in these arms either, also checked the top mounts, fine here also.
    One thing i did notice is that the rubbers in the anti roll C links look abit tired but i can't see any movement. Although it sounds like the noise is coming from that sort of area. They don't look like the sort of thing to knock like the ball and socket type
    Do these have a tendancy to fail? Am i missing something?? Its driving me mad!
    Please any help would be greatly appreciated!!
  2. Re: A4 Avant B7 Front Suspension Problems!
    May 2008
    Could well be the anti-roll bar/bushes that are on the way out.
  3. Re: A4 Avant B7 Front Suspension Problems!
    Nov 2010
    Birmingham, uk
    upper lower arms mine were split when going over a speed bump there would be a noise coming from the driverside suspension also when you give it some the noise would come back like a loud knock i changed my gearboxmount and had the steering rack recon aswell turned out to be these upper lower arms hope this helps
  4. Re: A4 Avant B7 Front Suspension Problems!
    Sep 2008
    chester
    17 Post(s)
    I would say the ARB bushes,having all the other work done is highlighting the wear in the bushes,its that distinctive clunk when going over even small holes in the road,for the cost of some new ones I would change them anyway.
  5. Re: A4 Avant B7 Front Suspension Problems!
    Oct 2009
    Cambridgeshire, UK
    Thanks for your input guys!
    Nevo i think you may be right, for the cost of new'uns, i may as well get them changed!!
  1. "How To" change b7 a4 front grille
    By JR001 in forum Audi
    Last Post: 17-06-2010, 01:41 PM
  2. New Audi A4 2.0TDIe
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-01-2010, 01:28 AM
  3. New A4 S Line details
    By Brioss in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-03-2008, 06:35 PM
