Thread: steps for replacing coolant on tdi?
  1. steps for replacing coolant on tdi?
    Nov 2010
    hampshire
    Well after another very cold night i cant risk it anymore by having too much water in antifreeze....
    Going to chsnge the whole lot today with halfords advanced stuff.
    Could anyone guide me to some steps on changing coolant for a tdi 1.9 2003 reg please? Is it relatively straight forward?
  2. Re: steps for replacing coolant on tdi?
    Jun 2006
    UK, Mids
    This is what I do one mine...
    Go for a drive so it is warm ~60-70˚c.
    Get home.
    Turn the heater to full and leave the ignition on.
    Remove reservoir cap.
    Unscrew the plastic tap on the bottom passenger side of radiator to drain it. (access via lower grille/foglight cover.
    Get a bucket of piping hot water, as adding cold water to warm engine is bad. As a guide, 60˚c is nice and hot 70˚c is just about the ouch! temperature.
    Screw in the drain **** on the radiator and refill the system via the reservoir.
    Run the engine with the cap off and add more hot was if needed.
    After a few minutes, stop engine, and drain again.
    Repeat until just plain water comes out and then drain for the last time.
    Now you have just plain water in places which can't be drained.
    Leave for a while to cool, and then add 66% of the total capacity of the system as neat antifreeze, and then top up with water. This will give the 66% mix required.
    Leave the cap off with the engine running so air can expand and bubble out of crevices in the engine.
    Leave the heater on and feel that it is hot.
    Audi A8 - 2015 - 3.0TDI
  3. Re: steps for replacing coolant on tdi?
    Nov 2010
    hampshire
    Blimey thanks very much. Glad i asked as i was just going to drain it cold from the lowest point and fill with halfords ready mix. I'll have a go thanks very much
  4. Re: steps for replacing coolant on tdi?
    Jun 2006
    UK, Mids
    Good luck, you can find the coolant capacity here...
    http://www.castrol.com/castrol/ifram...tentId=7044829
  5. Re: steps for replacing coolant on tdi?
    Nov 2010
    hampshire
    Bloody radiator plug! The most arkward toughest thing ever. I must have spinned it open for 20 min of agony only for it to trickle out only. Left for ages then an absolute bugger to tighten again.....
    Is the plug meant to come off completely? How long is the thread?
  6. Re: steps for replacing coolant on tdi?
    Aug 2007
    It only undoes a turn or 2 but then you have to pull it out for the coolant to drain, same with screwing it back in, you have to push and hold it in while screwing it up tight.
  7. Re: steps for replacing coolant on tdi?
    Quote Originally Posted by attila_tdi View Post
    "It only undoes a turn or 2 but then you have to pull it out for the coolant to drain, same with screwing it back in, you have to push and hold it in while screwing it up tight" a later post
    Poor atilla, he asked us for advice and snappy gave a good reply, we could have saved him some effort by telling him about the bloody plug before he found this out himself
  1. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  2. Losing Coolant Golf 2.0 GT TDI 140 (EGR Valve)
    By felinus in forum Golf MK5 - 2004 - 2009
    Last Post: 27-01-2009, 11:39 PM
  3. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
