Thread: Headlight connector melted
  1. Headlight connector melted
    London
    Last night popped into Halfords to get a new dip beam headlight bulb for my 2.7T Quattro saloon. I got the Halfords kid to replace it as it was cold and dark outside and it was the off side headlight where the plastic air intake ducts have to be removed first. I know lazy me!
    Anyway when he removed the old bulb the electrical connector was quite badly heat damaged and melted in places. Is that just a once in a while thing with a rogue bulb or a sign of something more sinister?
    I have had the car almost 3 years and this will be the third time I have replaced this same headlight bulb. And the near side one has been replaced twice. So with the original ones that were there when I bought the car that's 7 headlight bulbs in 3 or 4 years.
    No other lights on the car have failed in the entire 3 years I have had the car.
  2. Re: Headlight connector melted
    130 Post(s)
    1972 Post(s)
    Presumably these are standard rating 55w bulbs you are using?
  3. Re: Headlight connector melted
    London
    Hi Crasher, yes bog standard 55w bulbs I have never used super whites, blues or any other flavour of 'performance' headlight bulbs!
  4. Re: Headlight connector melted
    Apr 2009
    Epsom Downs
    The plating (or lack of it) on the connectors is suffering from thousands of heat cycles and starting to corrode.
    This puts the resistance up and the plug/socket combination startes to get hot (well, hotter than it's designed to). It also loses you a volt or two which translates into less brightness at the bulb.
    Next time the bulb packs up, consided replacing the spade connectors too...
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  5. Re: Headlight connector melted
    London
    Thank you that makes complete sense to me.
    I have to replace the connector anyway as the heat damage is pretty severe and will replace the spade connectors. Not sure how Audi sell them. Maybe connector, spades and wiring loom complete?
    Will do the other side while I am at it.
  6. Re: Headlight connector melted
    Apr 2009
    Epsom Downs
    There may be enough wire to just crimp or solder another spade connector on there....
    If not, extend it a bit with wire of similar diameter and an inline crimp/solder.
    Should be able to get spade connectors anywhere, even in these days of "fix by replacing the biggest module you can get away with" philosophy..
    Allroad 2.7 TT 2004
  7. Re: Headlight connector melted
    Feb 2009
    Glasgow UK
    strange...I've had 80w/100w in mine for 18 months or so and haven't had any problems !!
    Thanks for the info though and I hope you get it fixed mate
  1. '04 Golf Mk 5 Headlight adjustment
    By TASR12 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-08-2010, 07:47 AM
  2. HEADLIGHT PROBLEMS!! - one works, one does not.. HID's
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2009, 12:54 PM
  3. N Reg Headlight replacement
    By neil645 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-05-2008, 09:47 AM
  4. overheating & burning headlight switch - recurring fault
    By rdlb in forum Golf MK3 - 1993 - 1999
    Last Post: 07-03-2008, 01:17 PM
  5. Replies: 0
    Last Post: 08-11-2007, 08:54 PM
