Thread: Heater blower only works on max setting number 4?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Heater blower only works on max setting number 4?
    Jan 2009
    My heater blower only works on the max, 1, 2, 3, dont work, i have heard its the relay or something, Can someone just tell me were i can find it please to save it going into the garage thanks
  2. Re: Heater blower only works on max setting number 4?
    May 2008
    Resistor pack, bottom of the fan assembly, behind the glovebox
  3. Re: Heater blower only works on max setting number 4?
    Jan 2009
    So i just take the glove box out and i will find it? is this also how you take the heater motor out? because i have had water leaking through the air vents directly into the heater motor so i might need to change that aswell.
  4. Re: Heater blower only works on max setting number 4?
    May 2008
    It should be easy to find with the glovebox out of the way
  5. Re: Heater blower only works on max setting number 4?
    Jan 2009
    Found the resistor! Very easy job its under the glove box and goes into the heater with wires you simply unplug it an then unclip it off its connector!
  6. Re: Heater blower only works on max setting number 4?
    Norfolk
    Cut the thermal fuse off the resistor pack. Buy a fuse from Maplin for about £2.00 and solder it on. Leave a bit of the old fuse legs to solder to. It is harder to solder to the resistor terminals. OR buy a new resistor pack from VW for about £30.00.
  7. Re: Heater blower only works on max setting number 4?
    Jan 2009
    Dam I have just bought a 2nd hand one off ebay for £23, says comes with a 30 day warranty so if its not working i can always send it back! thanks though the maplin idea is alot cheaper! how would I know which fuse to order from maplin there is so many!
  8. Re: Heater blower only works on max setting number 4?
    Norfolk
    RA14Q should be ok. Cost about 80p.
  9. Re: Heater blower only works on max setting number 4?
    Mar 2013
    wales
    Hi, I have taken out the glovebox of my 07 Passat but cannot find the resistor! (Heater only works on 4.) Please can you tell me where it is? I've taken a couple of photos if someone could show me. Many thanks!
  10. Re: Heater blower only works on max setting number 4?
    Mar 2013
    wales
    I found the illusive bast*rd! Soldered a new maplin fuse but still only works on setting 4
    Get a new resistor?
  1. Fan / Heater Blower
    By stua4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2010, 07:10 PM
  2. Replies: 28
    Last Post: 02-11-2009, 11:08 PM
  3. Heater blower not working
    By scorpio40 in forum Touran - Sharan - Caravelle
    Last Post: 21-10-2009, 01:14 PM
  4. Sharan - Heater Blower Motor Brushes
    By Paul Sharan in forum Touran - Sharan - Caravelle
    Last Post: 18-02-2009, 10:39 PM
  5. S reg A3 - Accessing Heater Blower Motor
    By kimi in forum Audi A3 - Archive Topics
    Last Post: 26-10-2007, 10:54 AM
