Thread: electronic handbrake
Results 1 to 10 of 10
  1. electronic handbrake
    Nov 2010
    ireland
    a6 2005 electronic handbrake wont un-lock. The problem happens intermittantly. This has been ongoing for a long period of time. Has this been happening to others ans has this been flagged as a dealer problem. Thanks
    007
  2. Re: electronic handbrake
    Quote Originally Posted by offaly007 View Post
    007
    It is known problem on all electronic handbrake cars, i been told by my mechanic. Not many A6's suffers from it, he seen few A6 having issue with electric handbrake, mostly VW passats suffers from this problem.
    Its stupid question, but do you have your seat belt on, or do you keep your foot on brake when you trying realise parking brake.
    It did on my car over day, i been told seat belt should be on before realising parking brake.
  3. Re: electronic handbrake
    Aug 2009
    Sussex
    Quote Originally Posted by bakili View Post
    This is absolutely right - the handbrake refused to release on my brand new A6 soon after I bought it. I mentioned it to a friend of mine with a similar A6 and he pointed out the safety interlocks. They're described in the owner's manual. In my case, I'd just jumped out of the car to open a gate and hopped back in to drive forwards but didn't re-fit my seatbelt. I hadn't pressed the release button - I just tried to move away as normal.
    The handbrake should always release if you put your foot on the brake while pressing the button, whether you've got your seatbelt on or not.
  4. Re: electronic handbrake
    Aug 2010
    sunderland england
    I have the same problem on a 2005 A6 2.0 TDi. Its sometimes wont release when Im pulling away on an incline. I assume there is some sensor that tells the car your on a slope and dont have to press the foot brake to release?
    Its a right pain when it sticks as I haev a hill next to mine with traffic lights, I dread them turning red. Its happened a few times and the motorist behind me aren't too forgiving when Im getting flustered!
  5. Re: electronic handbrake
    here, but wish I was there
    If you switch the handbrake on but leave the car in D (assuming it is an auto) then the handbrake should automatically release when you push the accelerator - well it does on mine. Never come across the seatbelt thing though....
    Current - 2002 Audi A6 2.5TDi Avant quattro (loved), 2012 Ford S Max 2.2 tdci Titanium X (serves a purpose), 1983 VW Golf GTI campaign (loved)
    Previous - 2007 Volvo XC90 D5 SE Lux (gone, hated), 2002 Audi A3 1.9TDi Sport quattro (gone, liked and missed), 2011 Audi A6 2.0TDi SE (gone, loved and missed), 2007 Audi A6 2.0TDi SE (gone thankfully), 1999 Audi A6 2.5TDi quattro (gone, loved and missed)
  6. Re: electronic handbrake
    Aug 2010
    sunderland england
    Mine is a manual but is the same process , put it in gear and drive away. Workshe when it works! Annoying when it doesn't tho..tricky trying to keep revs up foot on brake and depress clutch
  7. Re: electronic handbrake
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    I find it's sensitive to whether you have fully depressed the clutch pedal before trying to move off. If you don't dip the pedal right the way to the floor, the brake often doesn't auto-release.
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  8. Re: electronic handbrake
    Quote Originally Posted by MFGF View Post
    MF.
    Also when having to select gear and move off quickly although this may be the equivalent to not dipping the clutch fully...
    2008 A6 2.7 TDI Le Mans (28k)
    2003 Passat TDI 130 Sport (98k)
    1999 Passat 1.8T Sport Tiptronic (152k)
  9. Re: electronic handbrake
    Nov 2010
    ireland
    Quote Originally Posted by sja View Post
    Thats the way my problems began but has been progressively getting. I cant use it now as it takes forever to unlock ususlly i will have to unhook the battery
  10. Re: electronic handbrake
    Jul 2009
    slough
    Hi offally i had this problem on my passat it would not release it did eventually but had a warning on the dash anyway i drove it home opened the windows to listen to the motors and when they worked the nearside motor ran for two or three times the amount the offside one did which made me suspect there was a problem with it i then removed it and found it had ceased i wasnt sure what to lubricate it with as it has a belt in it so anyway in the end i filled it with brake fluid and left it to soak after a couple of hours i tipped the break fluid out connected it to a battery charger and it worked perfectly there was a small amount of rust in it when i removed it but it didnt look that bad but obviously it was bad enough to stop it i think moisture got in the seal because the aluminium had corroded and formed a white powder around it i cleaned this up and put some boss whit pipe sealent on the joint and so far every thing is working as it should I also fitted new brake pads at the same time without connecting it to a laptop by undoing the two torx bolts on the motors and winding the pads back once the motors are off which isnt hard to do once i had disconnected the battery hope this helps allthe best Andy
  1. Electronic Handbrake
    By allanmb in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-06-2010, 01:44 PM
  2. Close call with the electronic handbrake today
    By jonsey24 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2010, 08:46 AM
  3. Electronic Handbrake
    By Sean Galway in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2010, 06:25 PM
  4. Passat Electronic Handbrake (doomsday scenario)
    By meoman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2009, 05:52 PM
  5. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
