Thread: Exhaust warning light is lit
Results 1 to 8 of 8
  1. Exhaust warning light is lit
    Oct 2010
    MIDDLESBROUGH UK
    HI EVERYONE !!! I HAVE A MARK 5 GOLF GT TDI. ITS A 2 LITRE ON A 04 PLATE WITH 59K MILES.IVE HAD IT FROM NEW AND ITS ALWAYS BEEN SEVICED BY A MAIN VW DEALER. ON FRIDAY I HAD JUST DONE A 40 MILE MOTORWAY RUN AND PARKED THE CAR UP TO GO TO A SHOP. ALL WAS FINE. WHEN I CAME OUT I RESTARTED THE ENGINE, DIDNT QUITE TURN IT OVER FOR LONG ENOUGH AND IT DIDNT START. I RESTARTED THE ENGINE BUT THE YELLOW WARNING LIGHT BECAME LIT. ALSO IN THE CENTRAL DISPLAY PANEL THE TEXT "EMISSIONS WORKSHOP" APPEARED. I WENT ROUND TO A LOCAL GARAGE AND THEY PLUGED IN A DIAGNOSTIC UNIT UNDER THE DASH. HE SAID TWO FAULTS WERE LOGGED BUT HE JUST CLEARED THEM AND SAID IT WOULD BE OK. THE LIGHT ON THE DASH HAD GONE AS WELL AS THE TEXT . THE NEXT DAY I DROVE ABOUT 8 MILES TO GET SOME FUEL . UPON RESTARTING THE LIGHT CAME BACK ON AS WELL AS THE WARNING TEXT. THE CAR RUNS PERFECTLY FINE . I THEN HAD TO DRIVE IT TO BLACKPOOL FOR A FAMILY DAY/NIGHT AWAY AND BACK ON VARIOUS ROADS,IE MOTORWAY AND "A" ROADS . COVERED 350 MILES .I CANNOT TELL ANY DIFFERENCE IN PERFORMACE OR MPG AND LIKE I SAID IT RUNS FINE . ANY IDEAS ?????????
    PS. IVE JUST NOTICED THAT UPON SWITCHING OFF THE ENGINE IT SHUDDERS TO A STOP. DOES THIS POINT TO THE INTAKE MANIFOLD FLAP VALVE BEING FAULTY. IF SO WHERES THE BEST PLACE TO GET A REPLACEMENT? MANTY THANKS GATSBY
    Last edited by GATSBY; 31-10-2010 at 03:13 PM. Reason: NEW INFO TO HELP FAULT DIAGNOSIS
  2. Re: Exhaust warning light is lit
    Sep 2008
    chester
    17 Post(s)
    Yes it is indicative of the flap going ,contact the garage that did the scan and ask them for the codes,then report back.
  3. Re: Exhaust warning light is lit
    Oct 2010
    MIDDLESBROUGH UK
    Thanks nevo, i just happened to be near the garage that plugged in the diagnostic reader . I will try and go back tomorrow to see if they will plug it back in. Vw said the part will be £300, euro car parts said £211.44 . Theres is a pierburg brand part number 422440260 . Are they of equal quality to vw's ? Or would i be better of buying the genuine article? Cheers gatsby
  4. Re: Exhaust warning light is lit
    Sep 2008
    chester
    17 Post(s)
    Peirburg one is fine,I paid £185 about a 2 years ago (15% vat)so thats seems ok,cars gone now so can't say about reliability.
  5. Re: Exhaust warning light is lit
    Oct 2010
    MIDDLESBROUGH UK
    THANKS AGAIN NEVO, THE OTHER THING AM WONDERING IS..... AM I GOING CAUSE ANY DAMAGE TO THE MOTOR IF A LEAVE IT A WHILE UNTIL I CAN AFFORD THE NEW PART?????????
  6. Re: Exhaust warning light is lit
    Sep 2008
    chester
    17 Post(s)
    Its ok to leave it for a while,it shuts the air off into the engine on shutdown,the only risk is if you get a runaway engine you've nothing to stop it! but that is very remote in the short term.you could try cleaning it,but if you've got to pay someone to do the work its not worth the bother,if your a DIYer its worth a try.
  7. Re: Exhaust warning light is lit
    Birmingham
    It is ok however the fuse can blow that protects the circuit. This fuse also provides power to a fan within the engine bay (can't remember exactly where!) which won't then be operating, just be aware!
    VW Golf Mk5 GT TDI 2.0 (140bhp)
    Black, 07 plate, goes faster when clean! Looking to replace but not sure what with..
  8. Wink Re: Exhaust warning light is lit
    Oct 2010
    MIDDLESBROUGH UK
    THANKS GUYS. I,VE CHECKED THE FUSE( NUMBER 24 IN THE ENGINE BAY FUSEBOX) ITS OK. IVE SOURCED A INTAKE FLAP VALVE FROM A BREAKERS FOR £65 INC VAT&POSTAGE. I WILL FIT IT AND GET THE FAULT CODES CLEARED/WARNING LIGHT RESET AND THE LET YOU ALL KNOW THE RESULT. FINGERS CROSSED
  1. Brake pad warning light
    By Wee Baldie in forum Alhambra
    Last Post: 14-10-2010, 07:10 PM
  2. Golf MK6 TDI DPF warning light !
    By moe360 in forum Golf MK6 - 2009 - 2013
    Last Post: 06-02-2010, 12:07 AM
  3. Exhaust warning light
    By ross130495 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-12-2009, 01:09 AM
  4. Exhaust Emissions Warning Lamp Lit on V5
    By AndyV5 in forum Chat - Completely Off Topic
    Last Post: 09-12-2006, 04:34 PM
  5. exhaust emission warning light v6 4motion
    By stevie-g- in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-11-2006, 11:27 AM
