Thread: Dual Mass Flywheel failure after only 39K miles
Results 1 to 10 of 11
  1. Dual Mass Flywheel failure after only 39K miles
    Aug 2010
    Harrogate, UK
    Beware of early Dual Mass flywheel failure in VW-Audi group cars!
    I have just discovered that the Dual Mass flywheel in my Golf Plus 1.9 TDI (55 plate)flew apart in the clutch bellhousing after only 39K miles. The symptom was a rattling for a few hundred yards and then the engine 'seized' and refused to turn over.
    After investigation by a local independent dealer, the fault was traced back to the flywheel. One of the springs in the flywheel had worked its way through the flywheel casing and had embedded itself into the bellhousing wall.
    After doing some research on the web it would seem that the dual mass flywheel, used to reduce engine vibration, has had some reliability issues in a few vehicles. In town drivers with frequent stop starts are more likely to suffer from a low mileage flywheel failure as its having to do much more work.
    The garage who fixed my vehicle said that the V -Audi-Skoda dual mass flywheel has demonstrated a poor reliability record due to the volume of vehicles they have had to repair. Taxi drivers are apparently already aware of this problem.
    I contacted VW about this reliability fault, but as I hadn't taken it to a dealer, they were not interested. I offered the parts, and an opportunity to review the vehicle but they declined.
    A replacement Dual mass flywheel from an independent dealer cost 900 pounds to repair. And it would have been more expensive had the spring caused additional damage to the bellhousing and broken the alloy wall seperating the differential from the clutch.
    This has been an expensive way to learn about dual mass flywheels and I would be interested to hear from anyone else who has had a dual mass flywheel failure on a VW, Audi or Skoda
    I guess I'll be thinking twice about purchasing another Volkswagen. Unseen low milage reliability issues such as this should not be a frequent occurence in todays vehicles.
    - Caveat Emptor
  2. Re: Dual Mass Flywheel failure after only 39K miles
    May 2008
    Its not just a VAG problem. Many cars are DMF equipped and they can be problematic for all marques.
  3. Re: Dual Mass Flywheel failure after only 39K miles
    130 Post(s)
    1972 Post(s)
    Almost every new car on the road now has a DMF, most supplied by LUK or Sachs so whatever you buy, you can’t avoid the issue.
  4. Re: Dual Mass Flywheel failure after only 39K miles
    Aug 2010
    Harrogate, UK
    I've heard that BMW and Mercedes have proprietery designs that dont have the same poor reliability.
  5. Re: Dual Mass Flywheel failure after only 39K miles
    130 Post(s)
    1972 Post(s)
    You have heard wrong, the garage across the road from mine specialises in BMW and Mercedes and he is always replacing DMF’s on them. One of my customers had a 330 which vibrated so badly due to a faulty DMF that it made my teeth hurt. BMW and Merc clutches/DMF’s are also made and designed by both Sachs and LUK.
    Feb 2010
    Ashford, Kent
    I work for a Ford repair agent, and we replace quite a few on low mileage 6 month old Focus', so it's not isolated to VW I can assure you!
  7. Re: Dual Mass Flywheel failure after only 39K miles
    Aug 2010
    Harrogate, UK
    Thanks for the replies.
    It's incredible that car manufacturers have introduced a part which has such poor reliability. Especially when it replaces a part that had such high reliability ie the single mass flywheel.
    No doubt the car manufacturers are well aware of the design shortcomings of this part. Its now no surprise that VW were not interested in this low mileage mechanical fault. And I had thought that the biggest reliability issue in todays vehicles was the electronics!
    My search is on for a car that doesnt have a dual mass flywheel.
  8. Angry Re: Dual Mass Flywheel failure after only 39K miles
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    I wish you luck finding a car without one! My neighbour had a flywheel fail at around 30k miles on an 07 plate Vauxhall Vectra diesel. He had to pay around £1500 for repairs at a main dealer, but in the end Vauxhall did a refund. Try typing dual mass flywheel into you tube, and you will see what a poor design they are!!
  9. Re: Dual Mass Flywheel failure after only 39K miles
    Aug 2010
    Harrogate, UK
    That's shocking! 1500 pounds! ...and there's never any guarantee that the manufacturer will stump up for the cost of repair.
    I've been reading about several owners who have installed a single mass flywheel and aparently Skoda is fitting a gunuine SMF replacement part to the TDI engine
    I'm now looking around to see if there is a genuine SMF replacement for the Golf Mk 5 1.9 TDI engine.
  10. Re: Dual Mass Flywheel failure after only 39K miles
    130 Post(s)
    1972 Post(s)
    We have just done a SMF conversion to an Octavia 110TDI that we installed a new engine on and with no apparent ill effects although I have not driven it myself yet. Converting a 5-speed 02J gearbox car is not difficult as the flywheel is off the shelf from VW and there are a couple of different duty levels of clutch to choose from such as the Golf 3 VR6. When giving a Golf 4 1.8T a serious boost in power we convert the car from a 220-mm DMF to a 228-mm SMF using the genuine VW flywheel and Golf 3 VR6 clutch and there are no apparent refinement problems but personally I have felt a reducing in refinement on TDI’s. The current replacement DMF’s from both LUK and Sachs appear so far to be much more reliable than those fitted originally. On my own car, when fitting a new engine I stuck with an LUK DMF and it has been fine for three years. Yes, there are SMF conversions for the Golf 5 105PS engine (and it can be done using genuine VAG parts) but to be honest the replacement LUK unit is very good, I have fitted a number of them and had no repeat failures.
  1. Do I have a Dual Mass Flywheel?
    By MAhearne in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2010, 03:49 PM
  2. Sharan dual mass flywheel
    By soup_dragon in forum Touran - Sharan - Caravelle
    Last Post: 05-07-2010, 05:07 PM
  3. Please Help Dual mass problems after 10 mnths.
    By volvofh in forum Golf MK5 - 2004 - 2009
    Last Post: 10-06-2010, 10:34 PM
  4. Question Dual Mass Flywheel.
    By Evobully in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2010, 02:00 PM
  5. Advice required on Dual Mass Flywheel - Golf 1.9 TDI MK5
    By Scoobypoo in forum Golf MK5 - 2004 - 2009
    Last Post: 10-05-2008, 12:11 AM
