Thread: URGENT ADVICE PLEASE!! 1.8t head replacement
  1. URGENT ADVICE PLEASE!! 1.8t head replacement
    Sep 2010
    Manchester England
    Hello, as described in previous posts my cambelt slipped and bent and snapped some valves causing me to need a replacement head,
    anyway i found a ADR replacement head, My Engine is an ARZ
    I did some research as to wether the the ADR would fit my ARZ and it said it would fit no problem , the guy who sold me it also said it would fit no prolem, now there are 2 differences i have noticed when examining the two heads
    Difference one, sensor on ADR that was not on ARZ What is is and do i need it?
    Difference two next (see pic 1 + 2) next to the thermostat housing there is another hole for a part which im not sure is! is it the dumpvalve?
    Now on the ADR head it has the screw holes for it to fit but no centre hole???? Can i make this head Work?
    Please see both pics, I would appreciate any help as i want to try and put it all back together tomorrow
    Thanks Very Much Ben
    http://tinypic.com/r/zmmn7p/7 (ADR RIGHT ARZ LEFT)
    http://tinypic.com/r/egogvp/7
  2. Re: URGENT ADVICE PLEASE!! 1.8t head replacement
    Sep 2010
    Manchester England
    HI! I have tracked the part down to the egr valve! but what can i do without there being a hole for it?
    Could i drill through??
    also what is the electrical sensor?
    Thanks Ben
  3. Wink Re: URGENT ADVICE PLEASE!! 1.8t head replacement
    130 Post(s)
    1972 Post(s)
    ADR and ARZ heads are different castings so I think you are going to struggle.
  4. Re: URGENT ADVICE PLEASE!! 1.8t head replacement
    scotland
    39 Post(s)
    Quote Originally Posted by coyleben View Post
    Differences Pictures, Differences Images, Differences Photos, Differences Videos - Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting (ADR RIGHT ARZ LEFT)
    What is this part? Pictures, What is this part? Images, What is this part? Photos, What is this part? Videos - Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
    The ADR head wouldn't have the electronic solenoid, this adjusts the valve timing via the ECU to clean up emissions, The ADR has a version of it but that works off oil pressure and doesn't have a solenoid. The drilling you see is for the secondary air injection pump, SAIP, this runs at start up, air is pumped into the cylinder head into the exhaust port this is to raise the temperature in the catalytic converter, the ADR didn't have that, I can't see why you couldn't drill through but I would take it to someone to have this done it could so easily go wrong and I don't think it would cost much.
    I'm unsure if the cam chain tensioner will swap over without any problems but as far as I'm aware the only difference is the solenoid, good luck and let us know how you get on?
    Calum.
  5. Re: URGENT ADVICE PLEASE!! 1.8t head replacement
    130 Post(s)
    1972 Post(s)
    Ancient post but I have fitted a new VVT unit to an AGU head fitted onto a BAM in a leon Cupra R and it worked perfectly.
  1. Head bolts 1.8t stripped head!
    By coyleben in forum 1.8T - Engine
    Last Post: 17-09-2010, 06:50 PM
  2. Got to be Gasket??
    By sammi49 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2010, 08:40 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Help - urgent advice please. Part not available for 3 weeks!
    By hc25036 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2007, 08:34 PM
  5. Head Gasket Replacement
    By pnuckched in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-12-2006, 10:43 AM
