Thread: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
Results 1 to 10 of 20
  1. Lightbulb Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    Sep 2010
    Portrush, County Antrim. N.Ireland
    Hi folks - my first post!
    I have just recently bought a mint Phantom Black A4 Avant 140 Tdi S-Line with 64k miles.
    Everything about the car is fine except that the engine has an uneven tickover. If you increase the revs to ~1000RPM, it becomes smoother. Normal driving and acceleration all appears fine.
    No error lights are apparent and there is nothing to suggest a fault.
    For those of you who have more experience of the B7, what would your advice be? I bought the car from an independant trader and it comes with (limited) warranty, but I am interested in the Forum Member's views and advise before doing anything.
    Many thanks.
    Charlie.
  2. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    Sep 2010
    Replying to my own post!
    I have picked on the the other existing threads under 'lumpy idle'.
    Looks like a few issues to investigate.
    I will start with the fuel filter/fuel pump items first though!
    Thanks.
  3. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    middlewich uk
    Quote Originally Posted by CharlieG View Post
    Thanks.
    i have the same and have learnt that it is a charitaristic of that engine, most say it is to do with the balance of the flywheel weights, just sit back and enjoy the ride
  4. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    May 2007
    knee deep in clunge
    14 Post(s)
    The term is egr bounce caused by exhaust gas recirculation however there are some issues with excess egr or fuel pressure but if these are ok its egr bounce and unavoidable
  5. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    May 2010
    london uk
    Quote Originally Posted by a8 tech View Post
    My A4 also suffers from egr bounce and i have learned to live with it. Can you tell me is there a software update that that sorts out this characteristic?
    Sorry to hijack this thread but i wanted to ask A8tech a question.
    i recently had a head light problem sorted out and the tech disconnected my battery, since then when my car is hot it is hard to start and makes a terrible noise when starting. I took the car to garage today and the guy said the noise was engine shudder because the engine didnt start, which strangely i felt better about. But there is still the problem of the engine starting intermitently from hot. Todays guy said he thought the problem was probably some thing to do with the egr valve reverting to default setting?? could this be the cause?? if so whats the fix??
    Please help
    Mike
  6. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    May 2007
    knee deep in clunge
    14 Post(s)
    Basic settings of exhaust gas recirculation
    MVB 3
    1) Start engine
    2) Start basic settings
    3) Idle speed
    The difference
    of actual EGR must be between
    EGR active and EGR inactive
    at least 120 mg/stroke
    There are a few sw updates for egr and fueling but I need your current ecu data
    poor starting could be early signs of fuel pressure loss which can be checked by taking a sample of fuel from the fuel filter and checking for excess soot.
    If the engine cranks slow then check the battery is in order, if there is a noise from the starter or flywheel then this could also be a sign of dmf failure.
    In some cases the internal grease from the dmf can be seen around the gearbox bell housing or starter motor which indicates failure or the early signs.
  7. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    May 2010
    london uk
    MVB 3
    1) Start engine
    3) Idle speed
    The difference
    Sorry but all that stuff blows my mind. I wanted to know if the suggested cause was most likely causing my symptoms or was it just a stab in the dark. I'd love to be able to give you the info you require but i cant seem to get anyone with Vagcom close enough to me to use their unit. The headlight guy was in suffolk 200m round trip! I'd take it to him if i thought he was able sort this out. I could take it to Audi bromley (nearest) but i'm frightened of the bill!!
    The engine turns over at normal cranking speed and there is no grease around the bell housing or starter motor. Dmf failure frightens the s*** out of me.
    For the record = A4 Avant 2005 2.0ltr tdi 7 speed auto.
    Mike
  8. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    May 2007
    knee deep in clunge
    14 Post(s)
    Ok, the multitronic ( 7 speed auto) uses a flywheel/ring gear similar to a dual mass and over time the spring loading plate loosens up causing a metallic noise when cranking and this sounds like your problem.The flywheel is not to expensive but the labour is around 7 hours remove and install.
    Best pop into audi for them to look at it
  9. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    May 2010
    london uk
    Thanks for that A8tech.
    I will get over to Audi asap. One final question if it is as you describe it may be,wouldnt the metalic sound be heard when the engine is below 90c. This only happens when the engine is at 90c (normal running temp for my A4) and not b4?
    and not every time i turn the key either?
    Mike
  10. Re: Audi A4 2.0 Tdi 140 2006 B7 - uneven tickover
    May 2007
    knee deep in clunge
    14 Post(s)
    even more likely to be the flywheel
  1. All-new audi a8 travels light to miami debut
    Last Post: 16-12-2009, 06:00 PM
  2. All-new audi a8 travels light to miami debut
    Last Post: 02-12-2009, 08:58 PM
  3. Record results for vehicles sales, revenue and profit
    Last Post: 12-05-2007, 08:33 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  5. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
