Thread: Number plate light not working
Results 1 to 8 of 8
  1. Number plate light not working
    Hi all
    I have Audi A4 54 Reg
    one of my number plate lights)rear ones) don't seem to work
    I have changed the bulb and it still dont work. one of them works but other dont. Any ideas what this can be or what i should look for?
    thanks in advance
  2. Re: Number plate light not working
    Ireland
    had the same thing and it was the bulb contacts that were poor.
    Take out the bulb and check for 12v with a multimeter.
    Im 99% it will be there..
    If it is then get some emery paper and sand the contacts. I also had to pull mine out for the bulb to get good contact..
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  3. Re: Number plate light not working
    hey i tried above and still no luck...is there anything else i need to look at?
  4. Re: Number plate light not working
    Ireland
    If there is no 12v at the contacts with the lights on then you most likely have a broken wire.
    Take out the bulb holder and check for wire damage and 12v right at the wires.
    15 535d 313bhp
    VCDS HEX V2
  5. Re: Number plate light not working
    I had the same problem on my A4 1.9tdi and it turned out to be the wiring loom in my boot, the one by the hinge. Some of the wires had split which also stopped the boot from opening, I could only open boot with key. I had to get a new wiring loom as failed MOT coz of numberplate light.
  6. Re: Number plate light not working
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Well if the loom turns out to be damaged I would just run a new line from the lamp that works
  7. Re: Number plate light not working
    Ireland
    Ya as above. Your lights are in parallel.
    See diagram (device X)
    You can check for continuity on both wires to identify broken line and replace or just run a new line from good bulb to bad bulb and back again (as per wiring diag)
    15 535d 313bhp
    VCDS HEX V2
  8. Re: Number plate light not working
    Dec 2010
    Chester
    Just done mine. Getting a decent contact was an absolute nightmare as the genuine parts I used seem to have much smaller contact areas than the originals I was replacing. I was determined to try everything to avoid having to mess about with wiring looms though and even considered tin-foil at one point!
    If anyone wants a few stainless steel H3 allen screws then i'll send some out.
    A4 AVANT 2.5tdi SPORT QUATTRO
  1. Replies: 23
    Last Post: 20-11-2011, 06:44 PM
  2. Number plate lights not working on B6 estate
    By paulni in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-01-2011, 12:32 PM
  3. coroded number plate light
    By Gordy180 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-12-2009, 01:04 PM
  4. Replies: 28
    Last Post: 02-11-2009, 11:08 PM
  5. Question Front Number Plate?
    By sambuka187 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-04-2009, 10:10 PM
