Thread: How to top up coolant
Results 1 to 10 of 19
  1. How to top up coolant
    Apr 2010
    London
    Most of you may laugh but i'd rather ask and be safe than sorry.
    Anyway.
    Checked coolant level this morning and noticed it has gone to just under the min level.
    Do i need to buy Audi coolant or will something from halfords do?
    If i buy Audi coolant do i need to mix it with water, or can i just add it in?
    What is the best thing to do?
  2. Re: How to top up coolant
    Oct 2005
    NEVER MIX COOLANTS!!!11
    With that out the way, if it's just a small amount missing, top up with water - I've always done it and I'm still alive as is my car.
    Now all I have to do is wait for the purists to pee on my campfire
  3. Re: How to top up coolant
    Mar 2008
    High Wycombe
    The coolant bottle should have printed on it what coolant to use. I expect it's either G12, or G12+. Probably G12+ It should be pink.
    Available from Audi, TPS or GSF etc.
    Do NOT use blue stuff from Halfords or anywhere!
    Mix with the right quantity of water (It should say the ratio on the bottle) and pour in to the max level. If I was doing it, I'd probably just pour in 50:50 water and G12+
    Edit: as Sam say, never mix coolants (he means the pink and the blue, not mixing it with water). You'll end up with a brown sludge which doesn't work very well.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: How to top up coolant
    Apr 2010
    London
    my coolant is pink i can see that quite clearly.
    so you're saying buy the official Audi coolant.
    i've seen a coolant in halfords:
    http://www.halfords.com/webapp/wcs/s...1&iozone=PDPz1
    like i say the level is gone just below the min level, so do you guys reckon it's ok to top up to max with cold tap water?
  5. Re: How to top up coolant
    Ireland
    If you can see that its pink then tap water fine for that amount.
    That halfords coolant is fine to use on your car too, expensive though!!!
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  6. Re: How to top up coolant
    Never mix coolant from Halfords with the Pink G12+, it will turn brown and sludgey and will destroy the seals in the coolant system.
  7. Re: How to top up coolant
    Jul 2007
    somerset
    8 Post(s)
    The latest stuff from TPS (Audi) is actually G12 ++ (thats right, plus, plus!!) Only use this stuff in your Audi, as long as its pink and has not been already mixed with the wrong stuff. I don't use tap water, i use de-ionised water, if not available, then de-stilled water followed by tap water. You can mix at different values, but i usually go for 50/50, this will be good enough for our winters.
  8. Re: How to top up coolant
    Ireland
    Quote Originally Posted by iwaters View Post
    Are you saying the pink halfords coolant (TL774D) whick 5up3rman is referring to mixed with pink G12+ will turn brown????
    15 535d 313bhp
    VCDS HEX V2
  9. Re: How to top up coolant
    Mar 2008
    High Wycombe
    If the halfords pink stuff meets the VW spec, then it should be OK, but if most people went to halfods and asked for coolant / anti freeze, they'd end up with blue ethylene glycol, which will not mix properly with G12 (although I think G12+ will tolerate it)
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  10. Re: How to top up coolant
    I've zoomed in on the image on the Halfords website. It says it meets TL774D, which I think is G12. TL774F is G12+.
    According to the workshop manual G12+ can be mixed with G11 and G12 so yes the Halfords pink stuff should be ok.
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. coolant mix. baffled by science ?
    By 1303S in forum Chat - Anything with wheels
    Last Post: 22-12-2009, 06:39 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. What is the safest way to dispose of old G12 Coolant ?
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2008, 03:38 PM
  5. Coolant system renewal!
    By Pernicitus in forum Golf MK3 - 1993 - 1999
    Last Post: 22-10-2007, 11:39 PM
