Thread: bulb warning light on
Results 1 to 10 of 11
  1. bulb warning light on
    Jan 2010
    glasgow uk
    the bulb warning light is on and the indicators are not working correctly but all lights are working.
    anyone else had this?
    mk6 1.4s
  2. Re: bulb warning light on
    May 2009
    Edinburgh
    Doesn't that suggest you have an indicator bulb out...or am I missing something?
    2010 Focus ST-3
  3. Re: bulb warning light on
    Jan 2010
    glasgow uk
    Quote Originally Posted by SC03OTT View Post
    All indicator lights working, very strange!
  4. Re: bulb warning light on
    Feb 2007
    What do you mean by ' indicators not working correctly ?'
    Indicators normally flash at a faster rate if one bulb is out on the side thats being illuminated - this includes the repeaters in the mirror housing.
    2010 Golf Mk6 TDI105 SE - now departed, replaced with A3 Sportback
  5. Re: bulb warning light on
    Jul 2008
    north west UK
    I used the search button!
    My car's bulb out warning lamp is on but all the bulbs are working correctly?
    Does this require a ******* to reset the computer or is there a DIY solution?
    TIA
  6. Re: bulb warning light on
    Feb 2007
    Woohoo, someone using the search function for a change
    The bulb out warning is detecting any voltage/current drop ina circuit, may be the bulb isn't fully blown.
    Are you sure non of the bulbs are blown ? - its difficult to see the front side/parking lights for the DRLs, and not everyone checks both number plate lights, the main beam bulbs and all the brake lights.
    If the older Mk4 Golfs are anything to go by, then i'd bet on a rear tail lamp, or brake light - as opposed to the front end,, and if an indicator is the issue then the rate of flashing of the indicators changes for the side thats affected (eg if one of the indicators ont he right isn't functioning then the other indicators and the dahsboard tell tale flashes a lot quicker than the left side).
    If there are no actual failures, then its probably a case of removing and reinserting each one at a time until the issue goes away - if this is the case start with the rear light clusters.
  7. Re: bulb warning light on
    Dec 2009
    Tichborne, UK
    This reminds me of the old joke about, "Is my indicator working?"
    "yes, no, yes, no, yes, no, etc."
    2009 Golf S Mk6 1.6 TDi (105PS)
  8. Re: bulb warning light on
    Feb 2009
    Northants
    Quote Originally Posted by frazmarti View Post
    mk6 1.4s
    Yep.....in 2009. Software update solved that IIRC.
  9. Re: bulb warning light on
    Aug 2009
    oxford
    The other day after I washed my car and the bulb warning light came on, after walking round the car several times and turnng everything on and off several times I finnaly spotted one of the rear number plate lights was out, I gave it a knock and it came on again and the warning light went out, without any need for a reset.
    Golf mk6 GT TSI 160 3 door Black with convenience pack
  10. Re: bulb warning light on
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Maybe so slowhand but that was a temporary fix not a permanent one its still got a bad connection somewhere.
    I'm aware thats VW's have this bulb failure warning which is a great thing infact its a fantastic feature that vehicles should have. I see loads of vehicles running about with bulbs out I normally flash the driver but today if someone flashes you it can be classes as road rage.
    Back in the 70's/80's the Austin Princess was the first vehicle that I've seen that had a bulb failure system, it had fibre optical cables running from each light. If the bulb wasn't lit the the fibre optic wouldn't be lit for that lamp. There was a vehicle layout in a panel and you switched on the different lights and pressed a test button to see it there all worked. That was 30 years ago with modern technology it can easily be incorporated.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  3. Bulb warning light on dash
    By jonsey24 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-07-2010, 09:53 PM
  4. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  5. sharan 04 bulb light warning
    By danger mouse in forum Touran - Sharan - Caravelle
    Last Post: 21-11-2007, 04:57 PM
