Hi, I have a 2000 Audi A4 1.9 TDI and a very wet passenger footwell.
I have un clogged the drain holes in the battery compartment, so its not that. I have tested to see if the windscreen is leaking, its not that. I have replaced the pollen filter and checked seals etc, its not that either.
What I have noticed is that when the air con is on I get a steady flow dripping from the foam ring behind the glove box.
Am I correct in thinking this is the evaporator drain, if so how do I unblock it?, or what can I do to stop this leak?
This is driving me mad as I have an old towel catching the leak, my glove box is sitting in the boot as I dont want to replace it until the leak stops....please help
