Thread: LED Sidelights
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. LED Sidelights
    May 2010
    caldicot UK
    Hey all!
    I purchased some LED sidelights the other day, and posted them back the very same day. For all considering LED sidelights, do not buy these. They say Audi on their website, so you'd think they would be Audi specific (obviously not sold buy Audi).
    As the LEDs are on each side of the pcb there is very little illumination. You can barely see any light shining from the light unit. I may try a different type of LED, maybe some with the LED's on the front of the bulb.
    Also, very tricky to install on the A4 as the side lights are at a funny angle in the light cluster. I checked the handbook to see if I was doing something stupid as I was struggling to get the original sidelights out... the handbook does not give instructions for changing, it actually says sidelights are to be replaced by a qualified technician!! Crazy isnt it! To change a sidelight you've got to book the car in. I wonder how much Audi charges for a replacement bulb + fitting ! Hopefully not an hour's labour + cost of the bulb!
    Linky is below of the type i purchased... do not buy!
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    If anyone has fitted led sidelights can you post some piccys? Be good to see sidelights on only, and another piccy with sidelights + dipped beam on.
    Many thanks!
  2. Re: LED Sidelights
    Norwich
    Try Philips BlueVision sidelights- they look cool too.
    Also removal of sidelights is a pain but can be done with perseverance and force.
  3. Re: LED Sidelights
    Dec 2009
    Swindon UK
    I have tried the 'No Canbus Error' ones from Autobulbdirect (didn't illuminate at all) and also these from ebay:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=130373986162
    The first one always lit OK but on fitting the second, it flashed a couple of times and went out. Had 4 bulbs so tried different combinations but when fitting the drivers side light it always failed. Refunds given in both cases.
    The ones from ebay had 8 LEDs, the one that lit was bright but unless you have the ice white in your headlights as well it looks odd.
    Heres a link to another possibility:
    http://www.car-mod-shop.co.uk/WHITE%...MD-LED%20bulbs
    I also had trouble getting the sidelights out and read on various forums, the only way to get them out is tug on the wiring! Plucked up courage and it worked.
    Good luck in finding some that work.
  4. Re: LED Sidelights
    May 2010
    caldicot UK
    cheers guys! Yeh i tugged on the wiring and when i switched the ignition on the sidelight wouldnt illuminate (normal bulb). I thought oh dear! What have i done now! Managed to replace the bulb and it worked. Thought i had knackerd the wiring up for a minute there!
    That piccy you posted... is that just with sidelights on? Look very bright!
  5. Re: LED Sidelights
    Norwich
    Yep that is sidelights only, I think the pic makes them look a lot brighter as it was taken when very dark. During dusk they are a blueish white colour, much better than the standard side lights.
    Also using LED side bulbs, do you not get the bulb out error?- I tried LED number plate bulbs from ECS which kept throwing this error, they are now on my Golf MK5 with no problems and look awesome.
  6. Re: LED Sidelights
    Jul 2012
    Slough
    I've got a slight issue, the A4 that I have already has LED sidelights fitted (by previous owner) however they are throwing up an error so I purchased some new 'CANBUS ERROR FREE" ones from eBay and they've been sitting in my boot for about 3 months because I can't get the existing ones out!!!
    I've tried to pull at the wires but didn't want to pull to hard - any tips on how to get them out? Is pulling on the wires ok?
    Thanks,
    Baz
  7. Re: LED Sidelights
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by Khindinio View Post
    Thanks,
    Baz
    It's easier if you remove the headlight.
    ....If only I was as smart as this bloody phone
    A4 2.5 tdi QS (mapped)
  8. Re: LED Sidelights
    Feb 2009
    Essex
    T8UPS, sponsor on here, he is your best bet, never had an issue with any LED's from him
  9. Re: LED Sidelights
    Jul 2012
    Slough
    Thanks guys, already have the lights so will try removing the headlights tomorrow - the previous owner has also fitted HID's so will see if the wires will have enough play in them to pull out the headlight.
  10. Re: LED Sidelights
    Aug 2009
    Near Lanark
    21 Post(s)
    I fitted led sidelights to mine and with the resistors I've had no problems. Nice and bright coupled with 6000k hids the look great.
    If you still want pics let me know what you want and I'll get them tonight in the dark.
    Edit: I didnt remove my headlamps and managed it fine
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  1. LED Sidelights
    By Adam Moran in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-11-2011, 09:43 AM
  2. LED Sidelights
    By mark- in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-09-2010, 11:28 AM
  3. LED sidelights and Xenon D2r or D2s
    By Aldo in forum Leon
    Last Post: 09-09-2010, 12:12 AM
  4. led sidelights
    By manity in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-04-2010, 01:27 PM
  5. led sidelights
    By jetbox in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-12-2009, 09:46 PM
