Thread: Vag Com 409.1
  1. Vag Com 409.1
    Dec 2009
    bolton
    Anyone live in the Bolton who would care to take some time out to show me how to operate the system. Purchased a lead and disc off e-bay managed to install the disc onto my laptop however I am not really sure of to operate the scans etc.
    Some help would be most grateful
    Car Audi a4 avant quattro (B6)
    Many Thanks
  2. Re: Vag Com 409.1
    Nov 2008
    Leeming
    You might want to try and post in the VAGCOM / VCDS forum
    https://www.vwaudiforum.co.uk/forum/f...play.php?f=211
  3. Re: Vag Com 409.1
    Ireland
    If it’s the fully registered version, on the main page just go into "autoscan", pick your model from the drop down list and press start. This will scan the complete car.
    Alternatively, you can go into "select control module", pick the module you want. EG: "engine" and press "fault codes"
    This will give you the errors in that specific module
  4. Re: Vag Com 409.1
    Dec 2009
    bolton
    I have tried the autoscan but when it comes to scanning the ABS 03 it says that the programs needs registering not the full version looking at the Ross tech link it say $99 I purchased the lead cd off eBay and just installed the cd do I need to register? thanks
  5. Re: Vag Com 409.1
    Dec 2007
    u got a snide copy
    you dont use discs with ross tech its all online
  6. Re: Vag Com 409.1
    Jun 2008
    Mold
    The unregistered version will still let you scan for fault codes, you'll need the ignition on to scan all controllers...
  7. Re: Vag Com 409.1
    Feb 2010
    Nicosia, Cyprus
    Copy version could well stop working at some time. That has happened to me and I had to buy 3 different wires from ebay, cheap ones I must admit. Worked for some time, then stopped working altogether. the pc didn't recognize them. So I went and bought an original one and taken any fuzz off my head!
  1. VAG COM 409.1 "No response from interface"
    By Lebarron in forum VCDS - Help Requests
    Last Post: 07-12-2009, 03:43 PM
  2. vag com 409.1
    By ßÛŠΤΞЯ in forum VCDS - General Questions
    Last Post: 15-09-2009, 12:14 PM
  3. Reset service inspection light wit vag 409.1
    By giggsy07 in forum VCDS - General Questions
    Last Post: 04-04-2009, 12:14 AM
  4. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
  5. cam belt interval
    By lucifer in forum Audi A4 - Archive Topics
    Last Post: 29-01-2007, 07:12 PM
