Thread: How to tell CR from PD engine?
Results 1 to 9 of 9
  1. How to tell CR from PD engine?
    pixor Guest
    Hi All,
    I am looking at A3 Sportbacks with the 140bhp diesel engine and DSG gearbox, 2006/2007 models (or thereabouts).
    Is there an easy way to tell if the engine is a CR or PD version?
    Thanks,
    Mike.
  2. Re: How to tell CR from PD engine?
    May 2008
    CR wasnt available in 06/07 so they will all be PD versions.
  3. Re: How to tell CR from PD engine?
    pixor Guest
    Ah, thanks. When did the CR engines come in, and how would I tell?
    Mike.
  4. Re: How to tell CR from PD engine?
    Jan 2010
    Wakefield, West Yorkshire
    Not sure when they came in but I think the CR engine has a single exhaust rather than the twin on the PD version.
    No doubt someone will correct me if I'm wrong !!!
  5. Re: How to tell CR from PD engine?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    You can also look at the engine code printed on the sticker in the spare wheel well (or in the front of the service book) and compare it with other cars with known engine types.
    My A6 with 2.0 TDi 170 CR engine has an engine code of CAHA and Mrs F's TT 2.0 TDi 170 CR has an engine code of CBB.
    Isaac was spot on, though - a 2006/2007 car will have the old PD engine.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  6. Re: How to tell CR from PD engine?
    Apr 2010
    staffordshire
    Quote Originally Posted by MFGF View Post
    Cheers!
    MF.
    Hi MF, your missing a digit on the Mrs engine code, all CR engines have 4 digits, I'm guessing that should be CBBB!
  7. Re: How to tell CR from PD engine?
    May 2009
    69 Post(s)
    Quote Originally Posted by baylissboy View Post
    Doh! The sticker in the spare wheel well lists the engine code as "CBB CBBB" - it's typical of me to get it wrong when there's a 50:50 chance!
  8. Re: How to tell CR from PD engine?
    CR for both 140 and 170 came in late 08/58 plate diesels - PD will sound more like a diesel!.
    I got a 2.0T 58 plate & so was looking at all the options so can remember the change - it came in with the facelift.
    CR 140 had two pipes until stop start version came in.
    CR170 still has two pipes.
    Did you choose the car in the end?
  9. Re: How to tell CR from PD engine?
    pixor Guest
    Budget is looking a bit restricted at the moment, so I am looking at 08 140bhp CR diesel Jetta Sports atm. Finding it hard to get excited about them though. I know it's mainly styling, but Audis look so much nicer!
  1. Balance of power shifts for 2011 model year audi q7
    Last Post: 02-05-2010, 05:12 PM
  2. Bentley mulsanne – the mighty new v8
    Last Post: 17-04-2010, 10:15 PM
  3. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  4. Please Help Engine Light, Running Slighty Rough....
    By le19h in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-09-2009, 01:03 PM
  5. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
