Thread: fuel injectors comparing
  1. fuel injectors comparing
    Jan 2010
    Sofia Bulgaria
    Hello,
    Does anybody knows is it a good idea fuel injectors with Bosch part number 0280 150 902 to be replaced with Bosch part number 0280 150 905?
    OEM 037906031C Bosch 0280150902 205cc/min 15.9ohm
    OEM 037906031D Bosch 0280150905 255cc/min 15.9ohm
    Both of them are designed for 3 bar fuel pressure and have same resistance of 15.9 ohm.The only one difference is the flow rate per minute.
    I wonder how it will affect the acceleration,speed and engine performance in general? Is it possible to be increased?
  2. Re: fuel injectors comparing
    Sep 2009
    Thirsk, North Yorkshire
    Can you be more specific on what you're doing, and what the part numbers relate to?
  3. Re: fuel injectors comparing
    Jan 2010
    Sofia Bulgaria
    Quote Originally Posted by Tobster View Post
    Yes,I'll try to.My present fuel injectors leak so they must be replaced with new ones.
    When I start searching for replacement injectors in Bosch catalogue I saw that there is another part number almost the same as the part number of mine injectors.The only one difference is the higher flow rate-255cc/min.Mine injectors have 205cc/min flow rate.
    So if I'll choose to install those with the higer flow rate will it increse the horse power and acceleration?
  4. Re: fuel injectors comparing
    Sep 2009
    On diesels it generally doesn't without increasing the fuelling somehow; electrically or mechanically depending on the type of pump, but getting enough air in is generally more of an issue, even on turbocharged engines and particularly on 8 valve.
    I don't know a lot about petrol injection systems though; but I imagine similar rules will apply if not worse so being generally naturally aspirated. My mate's old Saab 95 has the Bosch k-tronic system, and increasing the fuelling just makes it run too rich and coke up.
    Someone else may provide better information though; I don't understand petrols with their stoichiometric ratios and distributor coils and all that paganism!
  5. Re: fuel injectors comparing
    Jan 2010
    Sofia Bulgaria
    I hope somebody who have an experience with increasing the horse power of petrol engines could tell more about that.
  1. Ran out of fuel on gt tdi please help!!!
    By combatkarl in forum Golf MK5 - 2004 - 2009
    Last Post: 10-08-2010, 02:34 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Please Help. Non Start - No Fuel Flow.
    By wallis22 in forum Archive posts
    Last Post: 13-01-2008, 03:10 PM
  4. Newbie - first post- looking to buy!
  5. VOLKSWAGEN REVEALS HIGH TEMPERATURE FUEL CELL TECHNOLOGY
    Last Post: 01-11-2006, 09:55 PM
