Thread: Driver side - Electric heated seat doesn't work!
Results 1 to 9 of 9
  1. Driver side - Electric heated seat doesn't work!
    Jul 2008
    Bristol
    As above,
    Driver side heated seat does not work for some reason. I have no idea where to start! Any suggestions, as to what it could be?
    For Sale: VW Passat 2.0 TDI Sport
  2. Re: Driver side - Electric heated seat doesn't work!
    Feb 2010
    Louth Ireland....
    Check your fuses first. Check all the connection blocks under the seat in case one is popped out...........let us know after that if still no joy.
    Ex Passat B6 owner......to many retrofits to mention !
  3. Re: Driver side - Electric heated seat doesn't work!
    Jul 2008
    Bristol
    Quote Originally Posted by richiemac View Post
    I checked all the fuses, they seem to be fine altough they are a few missing from both ends of the doors. 30amp, 35amp and a few others!
    I checked underneath and again, it seems okay can't see any loose connections!
  4. Re: Driver side - Electric heated seat doesn't work!
    Jul 2008
    Bristol
    I read this online, is this true?
    Heated seats:
    1. Start the car
    2. Turn the heater controls to zero.
    3. Turn ON the rear window defroster
    4. Turn ON the seat heater controls.
  5. Re: Driver side - Electric heated seat doesn't work!
    Jan 2010
    Lisburn, United Kingdom
    Quote Originally Posted by Zeb View Post
    Heated seats:
    1. Start the car
    What is this supposed to do? I would say it seems more like a connection issue somewhere. What fuses are missing and what are they off?
  6. Re: Driver side - Electric heated seat doesn't work!
    Jul 2008
    Bristol
    Quote Originally Posted by g-black View Post
    It somehow resets the seats!
    Fuses:
    30 amp and 35 amp, from both sides.
  7. Re: Driver side - Electric heated seat doesn't work!
    Norfolk
    Check the seat wiring to see if you actually have 12v when you switch on. Then you have somewhere to start.
  8. Re: Driver side - Electric heated seat doesn't work!
    Jul 2008
    Bristol
    Quote Originally Posted by martin1810 View Post
    Sorry, I don't understand where you have said 12v switch on?
  9. Re: Driver side - Electric heated seat doesn't work!
    Norfolk
    I meant with the seats switched on for heat, check the wires to the heated part to see if it has 12v. If it don't have 12V the fault is elsewhere. If it has 12v the problem is likely to be the heating element.
  1. A6 C5 Avant heated seat retro fit (front and rear)
    By Col in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-11-2016, 08:32 AM
  2. The efficiency standard – the audi a8 hybrid
    Last Post: 02-03-2010, 07:58 PM
  3. The efficiency standard – the audi a8 hybrid
  4. Embarrased driver of Seat Alhambra
    By asknights in forum New Member Introductions
    Last Post: 23-10-2007, 06:11 PM
