Thread: Damp Seatbelts
  1. Damp Seatbelts
    A funny one this. Just interested to see if anyone else has had this. When I put seat belt on part of it about a foot feels cold and damp. Have checked for wetness and foynd nothing. Anyone else encountered this?
  2. Re: Damp Seatbelts
    Jul 2010
    Brighton
    that will be water coming into the car via the door window panel (metel panel that bolts to the inside of the door with window motor attached to it) there is a seal around it that tends to leak, if it's your drivers seat belt most likely your driver door is causing the problem
  3. Re: Damp Seatbelts
    Aug 2009
    London, U.K.
    Yep - I've had this. It's easy to check - just get a pal to pour a jug of water against all closed doors and windows ...... and look for water coming out of the bottom of the door trim and dripping over the thresholds onto the carpet. (Note: damp carpet in the front passenger footwell could be a plenum drain problem).
    If it's a door seal problem - remove the trim and remove the bolts securing the inner steel subframe/pan (which supports the window actuators etc.). This inner steel sub-frame/pan has a perimeter gasket/seal which sometimes fails. The easiest fix [not a bodge] is to run a bead of good quality clear polysulphide sealant around the underside of this sub-frame/pan, bolt it back up, and wipe off any surplus .... then re-fit the trim etc. Mine have not leaked again (but keep an eye on your door drain holes etc.).
  1. 1997 Polo 1.4 Cold / Damp starting and running problems
    By mungo_55 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-01-2011, 02:19 PM
  2. Question PLEASE HELP! - Musty Damp SMELL in 2006 vw passat
    By saunders400 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-05-2009, 08:14 AM
  3. ## 2.0TDI - 05 Plate - Damp Rear footwell ##
    By RickT in forum Golf MK5 - 2004 - 2009
    Last Post: 17-02-2009, 06:42 PM
  4. Audi TT internal damp
    By TT Princess in forum TT - 8N Forum - 1998 - 2006
    Last Post: 21-12-2007, 05:11 PM
  5. damp carpets-front passenger side
    By laujen in forum Passat - Archive Topics
    Last Post: 20-07-2006, 11:49 PM
