Thread: 5w 40
Results 1 to 9 of 9
  1. 5w 40
    Dec 2009
    UK UK
    Just had my 06 2.0 TDI serviced at an indy garage (VW specialist).
    The invoice says premium 5w 40 oil was used. It does not mention the VW spec.
    I changed from long life to annual servicing, and before I was using 5w 30 (VW 507).
    Have they used the correct oil?
    Can I add 5w 30 to it (I still have 3L!!)?
    KP
  2. Re: 5w 40
    May 2010
    Crewe
    Quote Originally Posted by kipperphill View Post
    KP
    1stly I'd say no they haven't used the right oil this has been discussed here to some depth. See thread https://www.vwaudiforum.co.uk/forum/s...d.php?t=103144
    2ndly nope I wouldn't mix oils
    2001 fiat Brava (aka Shelly) Sold/2003 fiat Stilo (aka The Beast) Crashed/2003 fiat Stilo (aka The Beast 2) Sold/2006 Passat S TDI sold
    Current:2007 Honda Civic Type S GT/2009 MKVI GTI
    Call me ESSE
  3. Re: 5w 40
    Dec 2009
    UK UK
    Quote Originally Posted by esse_esse View Post
    Thanks for the reply. That thread suggests that the 505.1 spec oil, which can be used for fixed service intervals, is likely to be 5w40 - so I think it will be OK.
    I'll take your advice on not mixing oils, I'll have to buy more!
    KP
  4. Re: 5w 40
    May 2010
    Crewe
    KP
    No prob mate as long as you're sure
    That reminds me I have some 5W 40 ABOUT 3.5 - 4L left over from my stilo days do you wanna buy that off me
    Call me ESSE
  5. Re: 5w 40
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Not all 5W-40 oils are approved to 505.01 specification . If it hasn't got the spec number on the container it's not approved . The 505.01 spec is important in that this oil was released for VW PD engines to provide the high oil shear strength required by the PD engine to combat the high unit injector camshaft loading. If you use other oils that do not meet this spec , then you run the risk of high camshaft lobe wear.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: 5w 40
    May 2010
    Devon England
    i get my oil from TPS so i know its the right stuff
  7. Re: 5w 40
    May 2010
    Crewe
    Quote Originally Posted by vwcabriolet1971 View Post
    The stuff I have is Drivetec 5w40 fully synthetic spec VW 505.00 so from what you're saying he couldn't use it anyway or could he?
    because it is dirt cheap compared to most oils comes in @ £20/5l from my local motorfactors
    Call me ESSE
  8. Re: 5w 40
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    505 spec oil was OK for the old pre PD engines ( before 2001) . These pre PD engines had conventional high pressure pumps ( mounted on outside of engine ) and injectors.
    PD engines with unit injectors with pumps / injectors inside the engine need the 505.01 spec for the reasons mentioned in previous post.
  9. Re: 5w 40
    May 2010
    Crewe
    Understood makes perfect sense now
    Call me ESSE
