Thread: Door not opening from outside
Results 1 to 10 of 13
  1. Door not opening from outside
    slimgeo Guest
    My rear passenger door will not open from the outside after unlocking the central locking system but after opening from the inside works fine until the car is locked again.
    Has anyone else had this problem or know what could be causing it.
    Any advise would be greatly appreciated.
  2. Re: Door not opening from outside
    May 2010
    Crewe
    Guessing this is the same thread a son UKP
    When you unlock the car are you pressing the unlock botton once?
    If yes you need to press it twice sequentially
    Post back if this don't work
    P.S. if you have full MFD you should be able to change this it should be something like driver lock if you have half MFD you will need VAG.COM I'm afraid. Someone on here will have one if you don't and I'm susre they'll be more than happy to disable this option for you if you do not want it if not it is off to the dealers/independent garage I'm afraid
    Can't post smilies so BIGUP lmao
    2001 fiat Brava (aka Shelly) Sold/2003 fiat Stilo (aka The Beast) Crashed/2003 fiat Stilo (aka The Beast 2) Sold/2006 Passat S TDI sold
    Current:2007 Honda Civic Type S GT/2009 MKVI GTI
    Call me ESSE
  3. Re: Door not opening from outside
    Mar 2008
    High Wycombe
    is it just one door, or all passenger doors. if all, then it may be the security locking. If it's just one, then it could be that the central locking motor is faulty, so it doesn't unlock until you pull on the inside handle, which unlocks it, solving the problem until you relock it.
    You'll have to remove the door card to see what's happenning with the lock (you might have to remove the other side aswell to see what should actually be happenning)
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: Door not opening from outside
    Apr 2007
    France
    12 Post(s)
    Do a search. There a quite a few variations on this not-unlocking problem, and various solutions here.
    1996 Laguna 2.2D
    1977 MGB roadster
  5. Re: Door not opening from outside
    Jan 2010
    Lisburn, United Kingdom
    There is a very common fault with the door locks. My back door hasn't opened from the outside for about 6 months. You get used to it after a while!
    There is a quick fix, lower the window and pull the I side handle and the outside handle at the same time. This will re-engage the latch that comes loose. Try it a couple of times as it doesn't usually work first go. If this fails, slam the door a couple of times, but put the window up for this as it's more secure.
    Once you get it working again, assuming it's the latch that had coming loose, it won't be a permanent fix. Were the catch is slipping, it will have worn down and you will fond the problem becoming more frequent. Try to afford pulling the door handle when the door is closed and pulling both handles at the same time.
    3 1 0
  6. Re: Door not opening from outside
    Nov 2008
    Sincere thanks for the quick fix. It worked a treat first time :-)
    Problem was with drivers door and only occurred after I asked my 9 year old to check if I'd locked the car. Naturally he pulled on the drivers door handle and you've guessed it, it then stopped working from the outside!
    For reference it's a 2007 Passat Estate 2.0 TDI and problem had never occurred before.
  7. Re: Door not opening from outside
    Ireland
    Just has the same problem with the front passenger door. The trick posted by NickPicks worked a treat!!
    Many thanks
  8. Re: Door not opening from outside
    Feb 2009
    Glasgow UK
    Guys, not sure on this, but it could be a possible, so maybe worth checking out?
    My sons Renault Clio ( 2000 ) has just had a similar problem. The drivers door and boot would lock / inlock no problem, but the passenger door wouldn't
    Listening intently to whichever door wouldn't lock / unlock as you click the fob showed that there was no noise coming from it......Ie - you can usually hear a click or smilar as the solenoid etc does its thing.
    We took the door card off and replaced the solenoid and now all is good again
    solenoid from the dealer was £70 and fitting would be approx £150, but we got a used unit from a scrappy £20 and a local bogit mechanic did the work for £20 so £40 all in.
    Could this be your problem? Maybe even faulty connections?
    Worthwhile looking into
    Hope this helps
  9. Re: Door not opening from outside
    Sep 2008
    Thanks to g-black for that quick fix, worked a treat but as you say it'll prob not last. not looking forward to taking that inner part off the door.
  10. Re: Door not opening from outside
    Aug 2007
    Hampshire
    Both driver and passenger door outside handles not working over the weekend
    Tried the window down and pull both handles trick and all is fine... for now!
    I do pull on the outside handles when they are locked some evenings so this may not help matters
  1. Boot opening
    By suky321 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2010, 10:57 AM
  2. Thermostat opening temperature
    By Froggy_130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-04-2010, 12:52 PM
  3. Please Help Problem opening boot after unlocking with remote: video
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-05-2009, 10:53 PM
  4. Tailgate opening (Avant)
    By alogbe in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-04-2008, 08:14 AM
  5. ROOF OPENING WHILST MOVING
    By SWORDFISH in forum Eos
    Last Post: 02-01-2008, 10:53 PM
