Thread: Esp Button Does nothing?
Results 1 to 10 of 12
  1. Question Esp Button Does nothing?
    Leicestershire
    Hi all,
    recently purchased a 2000 tt 225
    when switching the car on, no esp light comes on the dash, and when i press the esp button - nothing happens?
    what the heck could this be?
    how can i find out if my car has esp or if it was one without it? if it was without esp, then why would it have a esp button ?
    any ideas ?
  2. Re: Esp Button Does nothing?
    Southern County Softy
    20 Post(s)
    Scan the car for fault codes
    Look in the vagcom section for a member in your area.
    A4 2.5 tdi QS (mapped)
  3. Re: Esp Button Does nothing?
    Leicestershire
    scanned it and this is what came up...nothing to do with esp? any ideas?
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8N - Audi TT
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01: Engine
    Controller: 8N0 906 018 H
    Component: 1.8L R4/5VT 0003
    Coding: 10710
    Shop #: WSC 01236
    TRUZZZ8NZ11018427 AUZ5Z0Y9192148
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18446
    Shop #: WSC 01236
    Address 08: Auto HVAC
    Controller: 8N0 820 043 A
    Component: TT-KLIMAVOLLAUTOMAT D03
    Coding: 00041
    Shop #: WSC 01236
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 8N2 920 930 C
    Component: KOMBI+WEGFAHRS. M73 D52
    Coding: 05444
    Shop #: WSC 00000
    Address 22: AWD
    Controller: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    Address 35: Centr. Locks
    Controller: 8N8 962 267 B
    Component: Central Lock/Alarm D04
    Coding: 06858
    Shop #: WSC 01236
    6 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01616 - Signal Wire to Interior Monitor
    36-10 - Open Circuit - Intermittent
    00955 - Key 1
    09-10 - Adaptation Limit Surpassed - Intermittent
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    Address 45: Inter. Monitor
    Controller: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    Address 55: Xenon Range
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00010
    Shop #: WSC 01236
    2 Faults Found:
    01539 - Headlights Not Adjusted
    35-00 - -
    00776 - Level Control System Sensor: Left Front (G78)
    31-00 - Open or Short to Ground
    Address 56: Radio
    Controller: 4B0 035 186 D
    Component: Radio 0001
    Coding: 00517
    Shop #: WSC 01236
    1 Fault Found:
    00852 - Loudspeaker(s): Front
    36-00 - Open Circuit
    End --------------------------------------------------------------------------------------------------
  4. Re: Esp Button Does nothing?
    Canada
    IIRC the esp button needs to be held down/in for 3 seconds before it switches on/off
  5. Re: Esp Button Does nothing?
    Leicestershire
    yea iv tried that, still doesnt light it up on the dash....
  6. Re: Esp Button Does nothing?
    Canada
    How about using VCDS to monitor an output test on the switch? Also check the coding of the ABS unit is correct.
  7. Thumbs up Re: Esp Button Does nothing?
    Leicestershire
    Quote Originally Posted by onzarob View Post
    this sounds abit technical....any guides on how to do this pls?
  8. Re: Esp Button Does nothing?
    20 Post(s)
    Just a thought, could you swap the heated screen switch with the ESP switch
    to see if its a switch problem.
    I have no idea if they will have the same connections but it might be worth a try.
  9. Re: Esp Button Does nothing?
    Leicestershire
    Quote Originally Posted by kite View Post
    if it was a switch issue, surely it would still light up(then go out) when turning the key?
  10. Re: Esp Button Does nothing?
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    In response to the question, does the car have esp or not,yes a 2000 model 225 will,so it looks like you have a faulty switch
  1. 2.0 FSI ESP Light on AND Limp Home mode.....
    By Super76 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-07-2010, 09:40 PM
  2. Please Help Touran ESP problem 2.0tdi sport
    By chrisoluxor in forum Touran - Sharan - Caravelle
    Last Post: 06-06-2010, 09:28 PM
  3. TDi 1st timer, ESP button?
    By MrFannay in forum Golf MK4 - 1999 - 2004
    Last Post: 19-01-2008, 04:40 PM
  4. 2 button and 3 button fobs / remotes
    By Loofer in forum Archive posts
    Last Post: 07-08-2007, 02:08 PM
  5. Is ESP standard on Y reg A3 1.8T Sport ?
    By AlexP in forum Audi A3 - Archive Topics
    Last Post: 10-06-2007, 02:01 AM
