Thread: Removing the ABS pump ECU for repair
Results 1 to 10 of 13
  1. Removing the ABS pump ECU for repair
    May 2009
    manchester
    I've decided to send the ECU off my faulty ABS pump for repair to ecutest.com (I think they're called)
    They have asked me to remove ONLY the ecu bit which I'm told doesn't involve taking the pump off.
    Does anyone know or can anyone tell me the best way to do this and what kit I'll need please?
    It's my last hope of getting the car through MOT without having to sell one of my kidneys.
  2. Re: Removing the ABS pump ECU for repair
    130 Post(s)
    1972 Post(s)
    You unbolt it, it is held on with six screws but maybe someone has some pictures, I don’t.
  3. Re: Removing the ABS pump ECU for repair
    May 2009
    manchester
    Will I need to take the wheel off?
    Can I not just buy a new module rather than send it for repair? I don't mind stumping up a bit extra...
  4. Re: Removing the ABS pump ECU for repair
    130 Post(s)
    1972 Post(s)
    The module from VW is about £500.
  5. Re: Removing the ABS pump ECU for repair
    May 2009
    manchester
    Do ecutesting only repair then?
    I'll have a go at taking it out tomorrow and get it off to them anyway, it's just they advertise replacement modules for £200 - the girl I spoke to wasn't very helpful to be dead honest.
  6. Re: Removing the ABS pump ECU for repair
    Quote Originally Posted by bwfcspider View Post
    could be replacements from pumps that were beyond repair.otherwise the ecu was fine ???? hence £200 .
  7. Re: Removing the ABS pump ECU for repair
    May 2009
    manchester
    Just about managed to get the ECU off the pump. Hard work as I couldn't be bothered to take the wheel off.
    Will update when I've had it back and put it on how this saga ends. Hopefully.
    Thanks for all the input.
  8. Re: Removing the ABS pump ECU for repair
    May 2009
    manchester
    GOOD NEWS!!!!!!!!!!!
    The ECU was returned extremely quickly from ECU testing and after fitting it all is well again. YEAYYYY!
    Big thanks to everyone for their input, especially Crasher. This site has just saved me £700.
    Would definitely recommend ECU Testing to anyone with a module problem. Really impressed.
    Thanks again.
  9. Re: Removing the ABS pump ECU for repair
    Apr 2010
    dundee , scotland
    Had the same job done to my 99 passat, modulator sent to repairer only £130, job done with a warranty too and no annoying lights either !! Just need an auto specialist to fix my useless tiptronic box cheaply haha !!
  10. Re: Removing the ABS pump ECU for repair
    Aug 2008
    hi bwfcspider,
    what were your symptoms for your abs ecu fault?
    I've had esp light on for nearly 12 months, and codes indicate fault in abs pump, but unlike you the repairers want the whole unit, much more difficult job, and more inconvenient re car usage. (7-10 day service). Your posts almost made me get the job done, but now I'm discouraged.
    cheers, zillfish
  1. need correct abs pump anyone breaking late vr6
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-10-2009, 05:25 PM
  2. Question ABS Light - Golf 2.0SE Estate
    By garybauer61 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-05-2008, 11:52 PM
  3. ABS water pump -How much play is too much play?
    By emtee in forum Golf MK3 - 1993 - 1999
    Last Post: 13-04-2008, 12:47 AM
  4. Golf GTI 16V ABS Pump Problems - Help!!
    By oriches in forum Golf MK3 - 1993 - 1999
    Last Post: 03-12-2007, 09:55 PM
  5. ABS control module 1998 VW Passat GLS 1.8L turbo
    By adrian537 in forum Chat - Completely Off Topic
    Last Post: 13-11-2007, 11:02 PM
