Thread: Can Gateway Location
Results 1 to 10 of 16
  1. Question Can Gateway Location
    daclyn Guest
    Golf 1.9tdi 55 plate Plus.
    Location of Can Gateway Please ( Have upgraded radio to a RCD510 and have
    Battery Drain, so need to fit new Can Gateway).
  2. Re: Can Gateway Location
    Nov 2008
    folkestone.kent
    instrument panel ............why would the can gateway drain the battery ?
  3. Question Re: Can Gateway Location
    daclyn Guest
    RCD510 radio is an 09 model and the Golf is a 55. Battery drain is about 1 amp. and overnight drains battery.
    An updated Can Gateway drops the drain to 0.050 amps so I have been told.
    Do I have to remove the instrument cluster to gain access or is there another way??
  4. Re: Can Gateway Location
    Nov 2008
    folkestone.kent
    as far as i know its a compete cluster,why does it take that amount of current to keep it awake.....can you not recode the gateway ? it sounds an expensive way to drop the current
  5. Re: Can Gateway Location
    May 2010
    Devon England
    somewhere on here (think it was ben) there is a thread or 3 about have the can system updated to stop the battary drain, i think it can be donw by changing software but dont hold me to it
  6. Re: Can Gateway Location
    May 2008
    You cant recode a CAN gateway to fix the battery drain issue, its not in the instrument cluster either.
    http://www.my-gti.com/2296
  7. Re: Can Gateway Location
    Aug 2010
    Harrogate, UK
    I've read the article here http://www.my-gti.com/2296 but the canbus gateway on the golf plus does not appear to be in the same location as the golf GTI discussed in the thread. I've had a good look in the drivers side footwell and cant find a canbus gateway.
    Can anyone confirm that the canbus gateway on a golf plus is behind the instrument cluster (before I remove it)
    Thanks.
  8. Re: Can Gateway Location
    Aug 2010
    Harrogate, UK
    Found this youtube video which helps locate the CAN bus gateway on a Mk5 Golf GTI. The video shows a Right Hand Drive vehicle.
    http://www.youtube.com/watch?v=Y3hams1Z0CI
    Unfortunately it hasn't helped me locate the gateway on a Mk5 Golf Plus,
  9. Re: Can Gateway Location
    May 2008
    Some are behind the glovebox, depends on age of car I think.
  10. Re: Can Gateway Location
    Aug 2010
    Harrogate, UK
    Thanks, I'll try the glovebox tomorrow. Its a 55 plate Golf Plus 1.9 TDI.
  1. How To Fitting a Dension Gateway (100) to an A4 B6 / B7
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2011, 10:08 PM
  2. Question Can Gateway Location
    By daclyn in forum Golf Plus
    Last Post: 03-09-2010, 08:03 AM
  3. GATEWAY...step by step guide on how to re-code the gateway
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-06-2010, 01:15 PM
  4. Replies: 1
    Last Post: 20-12-2009, 03:18 AM
  5. location location location
    By Shak in forum Passat - Archive Topics
    Last Post: 15-08-2006, 07:54 PM
