Thread: Tyre Pressure Monitoring System (TPMS)?
Results 1 to 10 of 20
  1. Tyre Pressure Monitoring System (TPMS)?
    Bratty Guest
    I am VERY uninpressed with this option, It is useless! even though I had a large difference in tyre pressures between front to back Nothing!!
    Dunk
  2. Re: Tyre Pressure Monitoring System (TPMS)?
    Chester-le-Street, United Kingdom
    i can only guess that it hadn't been zero'd correctly?
    apparently it's very easy after adjusting pressures, some switch somewhere,
    possibly in glovebox?
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Tyre Pressure Monitoring System (TPMS)?
    Bratty Guest
    Recalibration is through the MMI but even so, my confidence in the system is ZERO. I mean I even had 18 inch wheels on the right axles and 19 inch wheels on the left (to check for clearances before having to buy another two tyres!) NOTHING. There is no check sytem to reassure you that the system is even active ie. the light on the dash (at least on my car!!?!!) never comes on even when you activate the key in the ignition (unlike ESP etc.).
    Safety feature, Yes! but would not loose sleep if it was not specced on a future purchase, if you blow a 19 inch tyre at UK national speed limits you should not really be automatically visiting a mortuary as the tyre wall itself is fairly stiff and you have 19 inches of metal to run on (as long as you realise!!?!! and do not try and drive from London to Edinburgh with it).
    Dunk
  4. Re: Tyre Pressure Monitoring System (TPMS)?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Is this system (TPMS) the full pressure monitoring system with special tyre pressure sensor valves or is the "flat tyre indicator" that works off the ABS ? I suspect its the latter and if so it does not measure tyre pressure. The "flat tyre indicator" uses the ABS system to monitor the relative speed of each wheel relative to each other. If one wheel is revolving a significant faster rotational speed than another , ( because its rolling radius is smaller) , then this is sensed as a puncture and the warning light is illuminated. In your case one wheel was not revolving faster than normal so the indicator warning light was not illuminated.
    If it was the full TPMS then this would not sense any problem either as it quite normal to have high rear tyre pressures when carrying heavy loads.
    I've only ever seen the full TPMS on the large VW 4x4s where the actual tyre pressure is displayed digitally on the dash display .This is a much more expensive option than the flat tyre indicator ( F.Tyre.I. was £30 on my MK6 Golf). Reports on the F.Tyre I. on the MK6 Golf section have been quite positive with advance warning of reduced pressure tyres, i.e. punctures.
    If the rolling diameters of the 18" & 19" wheel were close to the 18" size ( because the 19" wheels had lower profile tyres ) then the flat tyre indicator would not be activated.
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Tyre Pressure Monitoring System (TPMS)?
    Bratty Guest
    Would have expected some reaction from the abs sensor TPMS as the 19 inch combo has a larger overall diameter than the 18 inch (by about 8mm on paper!), and having the two different wheels on both axles and was driven for a good few miles, would have hoped it would react.
    Perhaps it is broken?
    Dunk
  6. Re: Tyre Pressure Monitoring System (TPMS)?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Quote Originally Posted by Bratty View Post
    Dunk
    May be broken but may be 8mm is at the limit of sensitivity. My MK6 Golf Flat tyre dash indicator yellow warning light does light up on ignition switch on and goes off when engine started. I suppose I'll only find out if it works is when I get a puncture.
  7. Re: Tyre Pressure Monitoring System (TPMS)?
    The best way to test it is to deflate one of the tires significantly, then drive a few miles and see if it picks it up.
  8. Re: Tyre Pressure Monitoring System (TPMS)?
    Apr 2010
    staffordshire
    It's the cheaper system, it does work off the ABS & it compares the wheel speed & it takes quite a few miles to register. The better system is the valves with the built in sensors that transmit the tyre pressures to a control unit, as fitted to RS4, RS6 & A8.
  9. Re: Tyre Pressure Monitoring System (TPMS)?
    I've got the ABS TPMS on my A4 - and I admit it works very well. I have a very slow puncture in the left front and every three weeks or so it tells me. Normal pressures for the 19" wheels are 36psi front and 35psi rear. It is alarming when the front left is dropping to 32psi. I think that is very good resolution.
    It works by comparing the angular velocity of each wheel to each other and the benchmark stored when you store the 'pressures' via the MMI. It uses many other factors too, such as steering wheel angle (turning right for example, the left front wheel turns more than the right rear with the others somewhere in between - it has to take this into account) and a 'rough ride' signal generated by the ECM.
  10. Re: Tyre Pressure Monitoring System (TPMS)?
    Jun 2008
    I think it says it all that somewhere along the line Audi decided to rename the feature "Tyre pressure loss indicator" along with the following disclaimer-loaded description: "A visual and acoustic warning when the system detects a potential loss of tyre pressure".
    When I first got the car I pumped up the tyres and reset the TPMS. I didn't check them for a couple of weeks because I assumed that the system would tell me if there was a significant drop. Unfortunately when I did check one of the rears had actually gone down from 36 to 28 without it telling me. Not a catastrophic loss of pressure, but enough to result in some nasty wear on the outside of the tread if I hadn't caught it.
    Looks like Zenerdiode has had a better experience, but I certainly wouldn't rely on the system and I would put the £75 towards something else if I buy another one.
    Steve
    Audi A4 (B9) Avant 3.0 TDI (272) Quattro with lots of toys
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Flat Tyre Indicator Switch Position
    By WeegieBob in forum Golf MK6 - 2009 - 2013
    Last Post: 11-06-2010, 01:08 PM
  3. Michelin tyre pressure advice (Winter)
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-11-2007, 12:39 PM
  4. Newbie - first post- looking to buy!
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
