Thread: A4 20v turbo Camshaft Position Sensor error P0343
  1. A4 20v turbo Camshaft Position Sensor error P0343
    Jun 2009
    Mold North Wales
    Hi yesterday my 2004 A4 1.8t 190 Sline wouldnt start , The starter motor would turn but no ignition eventually i mannaged to get it running after a few Coughs and farts but the engine management light came on.
    My friend came around with a diagnostics machine and came up with the code 16727 Camshaft Position Sensor P0343 G40 Signal To High. This morning i have replaced the camshaft sensor and cleared all the fault code's but the car is still having the same problem starting and the engine management light soon came on, the car runs fine when started when i can eventually get it to start.
    Has anyone had this happen to them? Dose anyone have any ideas of what to do next? And why it keeps showing this fault code?
    Any advice would be very helpfull cheers Matty.
  2. Re: A4 20v turbo Camshaft Position Sensor error P0343
    130 Post(s)
    1972 Post(s)
    I suspect you are looking at a wiring fault but it could be a pain to find.
  3. Re: A4 20v turbo Camshaft Position Sensor error P0343
    Jun 2009
    Mold North Wales
    That’s what i was thinking . The wires in the engine bay get hot and brittle ive got it booked into central VW & Audi so hopefully they can sort it out.
    Cheers for the reply and the Vulcan is awesome saw it at my works open day at broughton.
  4. Re: A4 20v turbo Camshaft Position Sensor error P0343
    Dec 2008
    cambridge
    Did u find the cure mate?
    having a similar problem with my a3
  1. Please Help Turbo failure again-help please!!!!!!!
    By Tyanu888 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2011, 09:18 PM
  2. Turbo clean or new / reconditioned turbo??
    By IW100 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-06-2010, 01:01 PM
  3. Please Help Will 1.8 20v gearbox fit on a 1.8 20v turbo?
    By deanis66 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2010, 07:52 PM
  4. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  5. New Audi A4 Cabriolet Range Update Bulletin
    Last Post: 09-11-2005, 08:37 PM
