Thread: Audi Allroad Suspension
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Audi Allroad Suspension
    Aug 2007
    Midlands, Uk.
    Can anyone help with Allroad suspension;
    Here's story so far, I had original problems with front suspension sagging, dashboard lights, G291 and control limit not reached fault codes, replaced front airbags and all was ok for a while....
    Then it started to refuse to change levels, really struggling to rise in height, fault codes as above. So I thought must compressor, struggling...
    350 quid later, last Sat decided to change compressor, to my horror, suspension completely failed, light on permanently, found out it was wiring to G111 relief valve. Fixed that temporary, really needs new connector housing, but also noticed wire hanging off connector going to valve block, so fixed that too, looked to me like it had vibrated itself apart (does anyone else think that Audis wiring is pants, no connector shrouding anymore!!)
    Suspension seemed to be working ok, no lights, up/down really quick, but it refuses to automatically adjust on the motorway, always staying at level 2. Incidentally I don't have the automatic/manual mode option on mine, just the level lights, I know I have had it working in the past, but any error code seems to make it fail, although there is no fault light indication.
    It seems strange cause the car has recently started to lean too, both front and back on the drivers side, but only down to a certain level then it stops.
    I need to check again for fault codes, plus does anyone think this may be a cal problem?? I did do a recal (402 mod) when the suspension originally started to act up, but wonder if it went wrong altough it was accepted.
    Anybody have any ideas??
    PS.
    Has anybody seen these self study packs on the web, specifically the allroad ssp_442;
    http://www.volkspage.net/technik/ssp/
  2. Re: Audi Allroad Suspension
    Apr 2009
    Epsom Downs
    Errrr....I may be a bit thick, but the list only appears to got up to 400....
    How do find 442?
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  3. Re: Audi Allroad Suspension
    Aug 2007
    Midlands, Uk.
    Ahhh, yeah, sorry... typo! The actual ones that are applicable are these, but just scan through the index;
    ssp_241 - Audi Allroad
    ssp_242 - pt1, Air Suspension
    ssp_243 - pt2, this one outlines the Allroad suspension.
    Very useful!
    Incidentally, the auto mode on the suspension has started to work again, forgot what the threshold was, seems to be around 80MPH, it certainly doesn't work at 120KMH as per the documents above, but maybe its different in UK.
  4. Re: Audi Allroad Suspension
    Ayrshire, Scotland
    18 Post(s)
    The leaning, check for fault codes first, could be a faulty level sensor.
    however if none and it is all working again as it should I would try recalibrating the height
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  5. Re: Audi Allroad Suspension
    Aug 2007
    Midlands, Uk.
    Well, I re-calibrated the suspension and all seems ok now.
    I did realise while doing the cal that;
    a) you need to make sure you're on a flat surface (I know sounds stupid), because even sllight slopes can cause problems.
    b) Don't sit in the car while you're calibrating, it makes a difference.
    No fault codes since, and auto mode works great.
    I think the old compressor was ok, so I suggest anyone with problems check the wiring first, to the valve block and the relief valve on the compressor. These were causing my problems.
  6. Re: Audi Allroad Suspension
    IE
    Would you be willing to part with your old compressor? I think mine is on its last legs...
    2001 2.5TDI 102 VW Transporter
    2002 2.5TDI 180 Audi allroad (gone)
    2004 1.9TDI 130 VW Passat (gone)
    2009 2.0TDI 143 Audi A4 Avant
  7. Re: Audi Allroad Suspension
    Aug 2007
    Midlands, Uk.
    Its funny because I scheduled the compressor to go on ebay at 19:00 (Fri 6th) earlier on, so if you're interested make a bid. Its ebay item 280545249409, just enter the number in the search field.
    I'm fairly sure its ok and if it helps someone then great....
  8. Re: Audi Allroad Suspension
    IE
    Any chance you consider shipping this to Ireland? I see you've got a UK only bidders policy so no worries if not.
  9. Re: Audi Allroad Suspension
    Dec 2010
    Dundee, Scotland
    hi guys, how did you re-set the suspension, as mine leans on the passenger side ??????
    many thanks.
    oh, and does anybody know where the valve block is located ?????
  10. Re: Audi Allroad Suspension
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by gpm72 View Post
    many thanks.
    does it sink or just not sit level?
    To calibrate the suspension level you need to use VCDS software, known as VAG COM, this allows you to input the actual heights at each wheel then the system re-sets itself level again. You would normally perform this after replacing a sensor or if you think one has been dislodged.
    The valve block is under the car sits just in front of the spare wheel well, it is mounted on the same bracket as the compressor, easy to see, it has all the colored pipes coming out of it.
    if you have suspension level issues best to get a fault code first using VCDS. why looking for the valve block?
    Andy
  1. Aluminium a5 coupe prototype shows the lighter side of audi
    Last Post: 04-10-2009, 02:16 PM
  2. Replies: 0
  3. The new Audi Q5: Sporty and versatile
    Last Post: 19-04-2008, 02:25 PM
  4. Audi set for 12th record-breaking year in a row
    Last Post: 31-07-2007, 08:34 PM
  5. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
