Thread: RCD 510 Firmware
  1. Question RCD 510 Firmware
    daclyn Guest
    Golf Plus 1.9tdi 55 plate
    Have just fitted a RCD 510 and have got BATTERY DRAIN overnight.
    Want to Change Firmware to 1100 or lower. ( will do CanBus upgrade at a later date )
    How do I do it and where can I obtain Firmware
    Any help please.
  2. Re: RCD 510 Firmware
    Kinross Scotland
    Go to VWnav .com RNS 510 section. and do you mean RNS ? as the firmware there is for the Nav unit, never seen RCD being updated ect. see this site :-
    http://www.my-gti.com/1101/upgrading...er-drain-issue
    Tiguan 2.0 4Motion 140PS 01/07/2013
  3. Question Re: RCD 510 Firmware
    daclyn Guest
    Yes it is a RCD 510, Drain 0.8 amps when switched off.
    VW Dealer knows about the issue but wants £50 to diagnose then if CanBus Module a further £149 + £50 to Vag Com the new unit.
    Has anybody fitted a new CanBus Module and has Info about VagCom??
    Is it possible to downgrade firmware with "Bricking It"?
  4. Question Re: RCD 510 Firmware
    daclyn Guest
    Cannot find a Firmware Downgrade for Radio so going down the Can Gateway route getting a "1K0 907 530 AD" module
    I have seen the info on the web about the upgrade but would like to here any helpful advice, VagCom etc.
    Many Thanks
  5. Re: RCD 510 Firmware
    May 2009
    Edinburgh
    Check out a site called VWNAV...I think it is. All your questions will be answered
    2010 Focus ST-3
  1. Replies: 46
    Last Post: 14-02-2014, 06:03 PM
  2. Opinions please...Factory fit RCD 510 or not?
    By barryjwong in forum In Car Entertainment
    Last Post: 24-03-2011, 08:35 PM
  3. RCD 510 question (not the usual battery one either)
    By SC03OTT in forum Golf MK5 - 2004 - 2009
    Last Post: 16-11-2009, 03:58 PM
  4. RCD 510 can it play lossless?
    By bozal in forum Golf MK6 - 2009 - 2013
    Last Post: 21-08-2009, 12:26 PM
  5. Rcd 310 to rcd 510 please help
    By veritas200700 in forum In Car Entertainment
    Last Post: 21-07-2009, 10:18 PM
